splash guards
Old Jun 19, 2010 | 03:37 PM
tdogg21's Avatar
tdogg21
2017 C3 of Year Finalist
Default splash guards
anyone using splash guards on their c5s? not sure if i need them or not. i use mine as a DD so i don't want to get it all crapped up.
if so, what kind and any pics?
Old Jun 19, 2010 | 03:46 PM
There have been a number of members that have adapted the C6 Z06 guards onto the C5 and also Altec makes some body colored ones for the C5. Places like Eclkers and Mid-America have the Altec's.
Old Jun 19, 2010 | 03:58 PM
Torchblue's Avatar
Torchblue
Try Apsis. They are a forum vendor. Use the link below.
http://www.apsisusa.com/C5%20Corvett...le%20index.htm
Old Jun 19, 2010 | 04:26 PM
tdogg21's Avatar
tdogg21
i like those. but i'm a little concerned that they don't post the price on their website. usually if they don't want to post the price it's probably more than i want to tell my wife i spent an pieces of plastic.
Old Jun 19, 2010 | 05:49 PM
dougbfresh's Avatar
dougbfresh
Look at your rocker panels, if they are all beat up you might want them.
Old Jun 19, 2010 | 05:56 PM
j84buick's Avatar
j84buick
It did a set on mine this spring. I went with the "slim" look like another forum member did. I did a ton of research and actually ended up doing this mod twice. Everything I learned is in my thread:
http://forums.corvetteforum.com/c5-g...with-pics.html
Old Jun 19, 2010 | 06:35 PM
vettman96's Avatar
vettman96
Had the Altec unit on all 4 corners but I removed the frts because they drug on everything. Placed modified c6 unit on the frt.
The Altecs are very good units but tend to set low.
Old Jun 19, 2010 | 06:47 PM
J.J. McGovern's Avatar
J.J. McGovern
I put a set of painted ones on a silver C-5 vert. I'm pretty mindful of the front end of my C-5's But I Scraped them up. Maybe I screwed up on the install.
Old Jun 19, 2010 | 07:31 PM
RSchleder's Avatar
RSchleder
I'm using the Apsis in the rear. IMHO they look great and protect the fender. They are a bit pricey but they do fit very well and look good doing it!
PS: they also make them for the front fenders I believe.
Old Jun 19, 2010 | 07:46 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
I have the C6 thin ones...I believe I was the first to post how to do these...just do a search on threads by me and you will see lots of detail...any questions just shoot me a message.
Old Jun 19, 2010 | 11:59 PM
O4-/-C5's Avatar
O4-/-C5
I just purchased front and rear Splash Guards from Lewis Five Motorsports.
I am extreamly happy with them.
Old Jun 20, 2010 | 12:50 AM
ValiantSailor's Avatar
ValiantSailor
O I dont drive in the rain or loose rock.
Old Jun 20, 2010 | 01:02 AM
yaknow's Avatar
yaknow
I recently purchased the Apsis rears @ $100 a quarter they are a bit pricey but, after destroying a set of C6Z06's it became very clear I have no fabrication skills. I decided I wasn't going to throw another $100. plus down the toilet on trying to improve my less average skillls.
Old Jun 20, 2010 | 01:25 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Apsis also makes these. They require no drilling. They are black plastic splash guards with pre-drilled holes in the front guards that line up with the stock wheel well liner screw holes. They install in minutes using the existing screws and are hardly noticeable, especially on a Black car. They don't extend too far past the rocker panels to cause clearance problems like many other splash guards do.
The rears install with built in clips and pre-applied 3M tape strips. I only use the front splash guards. I also use Cleartastic film for added protection.
Old Jun 20, 2010 | 08:16 AM
tdogg21's Avatar
tdogg21
do you have a pic of them from the back?
Old Jun 20, 2010 | 09:18 AM
bowtiebubba's Avatar
bowtiebubba
I have been looking at these. Did they fit right out of the box? No cutting or grinding to get them to fit?
Old Jun 20, 2010 | 09:27 AM
Jesse Asis's Avatar
Jesse Asis
WCC has the C6 type for the C5, for $159, I'm going for them. I installed C6 Z06 Rims and went with the 1" wider front and rear. Tires come up right to the edge of the fender, so I kick up stuff right to the outside... My only concern is there is some adjustment, I'm not sure if that means using a dremel tool to trim the guards as if I'm installing actual C6 splash guards.... will call and get confirmation.
To splash guards
Old Jun 20, 2010 | 09:31 AM
Mike98SilVert
Old Jun 20, 2010 | 09:41 AM
904pizza's Avatar
904pizza
Default $20
What about these
http://chevroletpartspeople.com/sear...(wide+w/o+logo)
Old Jun 20, 2010 | 09:44 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Base C6 guards work as well. Not as effective, but less expensive and subtle. Fronts will be a direct fit, rears will require minimal shaving.
To get them to sit flush, I used black-painted stainless screws since the mounting tape included just wasn't doing the job.
Fronts:
Rears
