head light module
Old Jun 21, 2010 | 11:18 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Default head light module
what exactly does the module behind the passenger side head light bucket control? i replaced the head light gears and now the lights won't come up sometimes. switch on lights on but do not pop up. cycle the switch a few times one or both may eventually come up. could this be the module?
Old Jun 22, 2010 | 02:00 AM
DeeGee's Avatar
DeeGee
I was going to suggest fuse #6 on the footwell panel but thats not the culprit if it eventually works. My guess would be the headlight switch on the stalk.
As a start buy some electronics cleaner and spray the switch well. If it gets better there's the issue. Eventually though - assuming that's it - you'll probably need to change it. If it's not that, the next one to check would be the hazard switch. Both well know for failing.
Old Jun 22, 2010 | 03:33 AM
hdff's Avatar
hdff
the head lights come on but they do not open, would this be a stalk problem? i would think that if either switch was going bad nothing work, lights or light doors??
Old Jun 22, 2010 | 06:00 AM
DeeGee's Avatar
DeeGee
As you can see from the wiring diagram, the multi function switch controls the headlamp door modules so this is quite common when the switch fails. I'd still give it a slug of cleaner first and cycle it vigorously to see if you can clean it up. Its been known to work.
To head light module
