Blinking headlight
Old Jun 22, 2010 | 11:35 PM
condor17twinzer's Avatar
condor17twinzer
8th Gear
Default Blinking headlight
Whats causing the left headlight to open and close a few times before closing?do they need to be syncronized?
Old Jun 23, 2010 | 01:50 AM
DeeGee's Avatar
DeeGee
That often occurs when work has been done on the headlights. Have you had the gears replaced or fitted HIDs recently?
First thing to try is to make sure that the insulators are in place
Number: 00-08-42-002
Subject: Left Headlamp Door Does Not Stay Closed (Shim Headlamp Door Motor/Actuator and Replace Insulators)
Model Year: 2000 Chevrolet Corvette
Condition
Some customers may comment that the left front headlamp door does not remain closed after the headlamps are turned off. Others may comment
that the left headlamp door closes when the headlamps are turned off, but then reopens. In either case, the right headlamp door operates properly.
Correction
Important
The following information applies to the left front headlamp door motor/actuator only. It does not apply to and should not be performed on the right front headlamp door motor/actuator.
Install one washer (2) between the left headlamp door motor/actuator (1) and the mounting bracket (3) at each of the three attaching bolt locations. Also replace the
insulator (4) on each of the two mounting bracket travel stop tabs (5) as shown. For information on headlamp motor/actuator removal, see the Headlamp Motor/Actuator
Replacement procedure in the Lighting sub-section of Body & Accessories in the appropriate Service Manual.
Parts Information
Part Number Description Qty Per Vehicle
11505463 Washer 3
16524060 Insulator 2
