Finally found out high temp problem
Old Jun 30, 2010 | 10:14 PM
96mogt's Avatar
96mogt
Default Finally found out high temp problem
The other day on my way home my temp creeped up higher than usual for the car. It got up to 235 which is alot higher than the normal 220 it normally stays at. It kept climbing until i got to a stop light and it cooled off just fine than back up when driving. So i went to the auto parts store and picked up a new thermostat thinking that might be the problem and also hosed out some crap from my radiator. Upon completion of that and burping the system it was fine at idle and still was creeping during normal driving. So i started to do process of elimination and began to think of what i did to the car since before it began to overheat and it hit me like a ton of bricks. I ordered a splitter from a shop and installed it. But its the poly rubber type of spitter that i was hesitant to try but did it anyways. So im assuming while driving it was folding over creating a block for the proper air flow. So i ripped it off and wallah!!! Never got above 198 the whole time and driving was back to normal. Man i never wouldve thought it wouldve hindered the airflow like it did. This is deff a learn as i go scenario and will not use that product again. I tell ya, i loved the look of the splitter but next one i get will be a PLASTIC one that wont flop over during normal driving conditions. Jay
Old Jun 30, 2010 | 10:33 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Great that your temps are down , but which t-stat did you get, stock/180/160, etc?
Old Jun 30, 2010 | 10:34 PM
moserbe's Avatar
moserbe
Good find.
Old Jun 30, 2010 | 10:52 PM
Congrats on solving your overheating problem.
Old Jun 30, 2010 | 11:37 PM
96mogt's Avatar
96mogt
I had a 160 in it, now its got a 187 in it, Im about to switch back to the 160 since i dont think thats what was the problem. Jay
Old Jul 1, 2010 | 03:04 PM
greyvette03's Avatar
greyvette03
Cruising
I thought that the computer and sensor determines when the t stat should open not the t stat itself.
Old Jul 1, 2010 | 03:13 PM
Dave68's Avatar
Dave68
The electric fans are programmed to come on far north of 160, so you should never just switch to a lower temp thermostat without reprogramming the fan activation temps.
Personally, I would not use a 160 degree thermostat.
Old Jul 1, 2010 | 03:41 PM
dougbfresh's Avatar
dougbfresh
WRONG-they work basically the same way since Fred Flintstone.
Old Jul 1, 2010 | 04:24 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
do you have pics of the splitter in question?
Old Jul 1, 2010 | 04:42 PM
96mogt's Avatar
96mogt
Its on Corvette Mods.com. I just looked at their site and they are no longer selling it on there unless i looked in the wrong spot. Jay
Old Jul 1, 2010 | 05:52 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Ah. gotcha. I have that one, but built an ABS reinforcement to keep that sucker in place, loking good and yes, somewhat functional.
This is the original rienforcement (sheet metal) but it was too sharp and too rigid. The ABS follows the same design, but is flexable to withstand impact without cutting though the material.
Old Jul 2, 2010 | 02:30 PM
96mogt's Avatar
96mogt
Yes sir thats it. Jay
Old Jul 2, 2010 | 02:39 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I ordered one of those sometime back, but when it arrived, I never put it on. I realized how flimsy it was and knew it would be nothing but a problem, plus I thought it looked cheap. I now have an ACI. I guess like the old saying goes, "you get what you pay for".
Old Jul 2, 2010 | 03:10 PM
96mogt's Avatar
96mogt
You can sure say that again! Jay
Old Jul 2, 2010 | 03:42 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
And you're reasoning for not using one would be what? Name one con to switching out to a 160 t-stat.
Old Jul 2, 2010 | 03:45 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Bogus cheap parts! Sometimes we live and learn on certain things - I am glad no harm was done, good catch
Thanks,Matt
Old Jul 2, 2010 | 06:18 PM
killain's Avatar
killain
Oldtimer
I think your going to throw a monkey wrench into the PCM software. The engine isn't ever get to the normal operation temperture. Mine is stock and it's nomal for it to run at about 200 degrees, and if I'm in stop and go traffic and the A/C on it runs at 205-210 degrees. But hay, maybe it will work fine for you. I'd be afraid of it running to rich as the temps float at the 180 degrees point ?
To Finally found out high temp problem
Old Jul 2, 2010 | 06:35 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
All this looks to be is a piece of garage door guard that sells on Ebay for astronomical amounts. You can pick one up at RONA or Home Depot for $15 bucks. There is a DIY thread on this "splitter." It looks horrid...JMO
Old Jul 2, 2010 | 08:31 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
That is why I pitched mine in the garbage once I looked at it. I h=now hav an ACI splitter.
Old Jul 3, 2010 | 12:28 AM
96mogt's Avatar
96mogt
Hence why my dog is using it as a chew toy now as well lol Jay
