Blacking out tail lights
Old Jul 11, 2010 | 06:01 PM
  #41
stealthC513's Avatar
stealthC513
Fruss48, it looks like a lot of people here including myself have done this so go for it if you like it, forget what other people think. If you are going to do it yourself its simple, this is how i did it. 1.) take all the lights out 2.) clean them very well, this is the most important part 3.) spray them until you get the shade of darkness you like and let them dry. Some people clear coat and sand them but mine came out pretty glossy and smooth without it so i didn't feel the need. Have fun and it looks really good on a black Vette
Old Jul 11, 2010 | 06:12 PM
  #42
fruss48's Avatar
fruss48
Thanks again stealthC5113.
Old Jul 11, 2010 | 06:16 PM
  #43
CatCam's Avatar
CatCam
Originally Posted by stealthC513
The picture of the Lambo is at a car show, there's a Toyota Camry in the background, you don't go to car shows? Also tinting breaklights are not illegal everywhere, here in Illinois law says that lights must be visible from a minimum distance of 500 feet and the spray that i used does still let the reflections from the lenses through, all products are not the same and laws are different everywhere.
Please state your source, i.e state law statue. While is gives a distance it also gives a LUX or LUMENS intensity. You can see one LED light for over a 1/2 mile, however, it's lux output is 0.0001 lux. This luminous emittance as a measure of the intensity as perceived by the human eye would be a little brighter than the brightest star in the sky (dim).
Old Jul 11, 2010 | 06:20 PM
  #44
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Since you referenced the state laws several times you must already have them book marked. Be much easier for you to post the link(s).
Since I doubt you can do that here is Ohio's:
Hmmm. One tail light visible at 500'
§ 4513.05. Tail lights and illumination of rear license plate.
(A) Every motor vehicle, trackless trolley, trailer, semitrailer, pole trailer, or vehicle which is being drawn at the end of a train of vehicles shall be equipped with at least one tail light mounted on the rear which, when lighted, shall emit a red light visible from a distance of five hundred feet to the rear, provided that in the case of a train of vehicles only the tail light on the rearmost vehicle need be visible from the distance specified.
Either a tail light or a separate light shall be so constructed and placed as to illuminate with a white light the rear registration plate, when such registration plate is required, and render it legible from a distance of fifty feet to the rear. Any tail light, together with any separate light for illuminating the rear registration plate, shall be so wired as to be lighted whenever the headlights or auxiliary driving lights are lighted, except where separate lighting systems are provided for trailers for the purpose of illuminating such registration plate.
(B) Whoever violates this section shall be punished as provided in section 4513.99 of the Revised Code.
And before you ask:
Brake lights; 500 feet
4513.071 Stop light.
(A) Every motor vehicle, trailer, semitrailer, and pole trailer when operated upon a highway shall be equipped with two or more stop lights, except that passenger cars manufactured or assembled prior to January 1, 1967, motorcycles, and motor-driven cycles shall be equipped with at least one stop light. Stop lights shall be mounted on the rear of the vehicle, actuated upon application of the service brake, and may be incorporated with other rear lights. Such stop lights when actuated shall emit a red light visible from a distance of five hundred feet to the rear, provided that in the case of a train of vehicles only the stop lights on the rear-most vehicle need be visible from the distance specified.
Such stop lights when actuated shall give a steady warning light to the rear of a vehicle or train of vehicles to indicate the intention of the operator to diminish the speed of or stop a vehicle or train of vehicles.
When stop lights are used as required by this section, they shall be constructed or installed so as to provide adequate and reliable illumination and shall conform to the appropriate rules and regulations established under section 4513.19 of the Revised Code.
Historical motor vehicles as defined in section 4503.181 of the Revised Code, not originally manufactured with stop lights, are not subject to this section.
(B) Whoever violates this section is guilty of a minor misdemeanor.
Amended by 128th General Assembly File No. 9, HB 1, § 101.01, eff. 10/16/2009.
And FYI the 500' is measured during the required hours for use of lights:
4513.03 Time for lighted lights on motor vehicles.
(A) Every vehicle, other than a motorized bicycle, operated upon a street or highway within this state shall display lighted lights and illuminating devices as required by sections 4513.04 to 4513.37 of the Revised Code during all of the following times:
(1) The time from sunset to sunrise;
(2) At any other time when, due to insufficient natural light or unfavorable atmospheric conditions, persons, vehicles, and substantial objects on the highway are not discernible at a distance of one thousand feet ahead;
(3) At any time when the windshield wipers of the vehicle are in use because of precipitation on the windshield.
Every motorized bicycle shall display at such times lighted lights meeting the rules adopted by the director of public safety under section 4511.521 of the Revised Code. No motor vehicle, during such times any time specified in this section, shall be operated upon a street or highway within this state using only parking lights as illumination.
Whenever in such sections a requirement is declared as to the distance from which certain lamps and devices shall render objects visible, or within which such lamps or devices shall be visible, such distance shall be measured upon a straight level unlighted highway under normal atmospheric conditions unless a different condition is expressly stated.
Whenever in such sections a requirement is declared as to the mounted height of lights or devices, it shall mean from the center of such light or device to the level ground upon which the vehicle stands.
(B) Notwithstanding any provision of law to the contrary, no law enforcement officer shall cause the operator of a vehicle being operated upon a street or highway within this state to stop the vehicle solely because the officer observes that a violation of division (A)(3) of this section has been or is being committed or for the sole purpose of issuing a ticket, citation, or summons for a violation of that division, or causing the arrest of or commencing a prosecution of a person for a violation of that division.
(C) Whoever violates this section is guilty of a minor misdemeanor.
Amended by 128th General Assembly ch. 1, HB 2, § 101.01, eff. 7/1/2009.
Looks like another fail...
Old Jul 11, 2010 | 06:27 PM
  #45
REZ1's Avatar
REZ1
This seems like the "which oil is best" argument. It goes on for everrrrrrrrrrrrrrrr
It appears that Fruss48 has decided to tint his taillight lens and is asking for help as
'How to' and what have fellow forum menbers used...
He did not ask for laws or to be treated like a red-headed step child...(redheads please forgive Me)
So lets help him out if we can. Just My 2cents
Old Jul 11, 2010 | 06:30 PM
  #46
damilleniumboy's Avatar
damilleniumboy
Originally Posted by blackmachdown
really?
whats this?
what about this?
yeah i guess porsches ferraris and lamobs dont smoke their lights
Those cars are sexy! I blacked out my side markers, and 3rd brake light, and I checkered my tail lamps. It looks good to me. I don't have any decent pics though. I will see if I can find one.
Old Jul 11, 2010 | 10:31 PM
  #47
stealthC513
(625 ILCS 5/12‑208) (from Ch. 95 1/2, par. 12‑208)
Sec. 12‑208. Signal lamps and signal devices.
(a) Every vehicle other than an antique vehicle operated in this State shall be equipped with a stop lamp or lamps on the rear of the vehicle which shall display a red or amber light visible from a distance of not less than 500 feet to the rear in normal sunlight and which shall be actuated upon application of the service (foot) brake, and which may but need not be incorporated with other rear lamps.
Doesn't say anything about LUX or LUMENS but i highly doubt a cop pulling you over for tinted lights is going to measure these, if they even know what it is. Anything else?
Old Jul 11, 2010 | 11:08 PM
  #48
cmeflibi's Avatar
cmeflibi
lotts of big butts (talking about the vette rear ends being shown)
Btw this thread is priceless. This guy will not admit defeat. Ive seen tons of cars with tinted lights. At a car show yes, but they DROVE the car there. It looks good. Im sure it won't be cool in 10 years, but hey, it's a fad.
I've seen the "halo" led tail lights and they are plenty bright. Almost too bright if you ask me.
Old Jul 12, 2010 | 03:19 PM
  #49
CatCam's Avatar
CatCam
Fruss48 - Sorry Dude, that spur in my saddle really getting to me....
If blackout is what you want to do, go for it.......
"Nothing sucks more than that moment during an argument when you realize you're wrong."......so with that we put this to bed.......
I hear If you **** off people on the Corvette Forum, they hunt you down and put bad stuff in your cheerios.....
Peace.
Old Jul 15, 2010 | 06:14 PM
  #50
memphis_vette's Avatar
memphis_vette
im using VHT nightshades as we speak. ill post pics when i am finished
Old Jul 15, 2010 | 10:29 PM
  #51
fruss48's Avatar
fruss48
No harm done catcam.
Old Jul 15, 2010 | 10:31 PM
  #52
memphis_vette
BEFORE
AFTER
Old Jul 15, 2010 | 10:53 PM
  #53
fruss48's Avatar
fruss48
Nice look memphis vette, could you go into detail the steps you did to get that look?
Old Jul 15, 2010 | 10:56 PM
  #54
Tom73's Avatar
Tom73
Sorry but this is one style trend that I have never understood. I just cannot see making a decesion to make the lights dimmer. To me, if anything, seems you would want to make them brighter.
Seems to follow the pattern of the "cool" guy who wears sunglasses at night.
Just my 2 cents. If it is not illegal in you state, go for it if you want. If it is illegal, as it is here in Texas, it will just give the LEO's one more excuse to pull you over.
tom...
Old Jul 15, 2010 | 11:13 PM
  #55
memphis_vette
i just dislike the red color i like silver and black together thats my excuse
Old Jul 15, 2010 | 11:14 PM
  #56
memphis_vette
all it takes is some sanding and then one coat for me
Old Jul 16, 2010 | 10:38 AM
  #57
bucwheat's Avatar
bucwheat
I bought the lens covers,that way if I need to convert back I don't have to buy new tail lights.I did use nightshades on my side markers , two coats wet sand lightly in between coats.
To Blacking out tail lights
Old Jul 18, 2010 | 11:08 PM
  #58
mickey_7106's Avatar
mickey_7106
so why say anything to begin with?
Old Jul 22, 2010 | 02:07 AM
  #59
doublec4's Avatar
doublec4
Old Jul 22, 2010 | 11:07 AM
  #60
Remo's Avatar
Remo
Default They Look OK To Me
They make it through the state safety check every year.
