Clean exhust tips!
Old Jul 23, 2010 | 11:01 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Originally Posted by Yello95
Windex makes me sneeze
You see Kenny Windex is good for clogged nasal passages too
Old Jul 23, 2010 | 04:06 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Yes Bill but but unfortunately it had an unpredictable side effect that I have been suffering from ever since...my wifey took a pic right after the incident
Warmest wishes,
Kenny
Old Jul 23, 2010 | 05:27 PM
Evil-Twin's Avatar
Evil-Twin
Yes Bill but but unfortunately had an unpredictable side effect that I have been suffering from ever since...my wifey took a pic right after the incident
Warmest wishes,
Kenny
Kenny, have you been lying again? The nose doesn't lie.
Old Jul 23, 2010 | 07:47 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
yea, thats me...Kenny the habitual liar
Old Aug 29, 2010 | 01:00 PM
pendan's Avatar
pendan
Yeah it's good stuff, not only does it clean stainless, but it also polishes it.. it's cheap, under two dollars , most super markets have it in the cleaning isle.. close to cleansers.
I am indeed a wealth of useless information
ET,
I have an '08 that I run pipes open always 40,000 miles, and the center two pipes are carbon baked. I have tried various methods to clean but to little avail. Last I tried Cerama Bright Ceramic/Glass counter top cleaner and it did help but only 50% there. Will Barkeepers take me all the way home?
Thanks P
Old Aug 29, 2010 | 02:26 PM
rudolph schenker's Avatar
rudolph schenker
Old Aug 29, 2010 | 03:56 PM
diverdan's Avatar
diverdan
Mine were stained, somehow, from the sooty exhaust water coming out (They came that way when I traded out my mufflers for some that had been modded) and I had no luck with Cermabrite, Brasso, or any other cleaner. I finally resorted to using a Dremel tool and polishing compound to get them cleaned up. Once shiny again, I hit them with a coat of Armor All Wheel Protectant, which some have reported as working well to keep them clean.
Edit: Whoops I accidentally ended up on the wrong thread. Well, I did the same the to the mufflers on my C5Z.
Old Aug 29, 2010 | 04:09 PM
runner140*'s Avatar
runner140*
Originally Posted by pewter99
Hmmm...I will keep that in mind. I have the original Borla Stingers and I can simply spray them with Simple Green and everything runs right off...no scrubbing at all. My new Borlas..not so much
That what I also use.
Old Aug 29, 2010 | 04:16 PM
robsc501's Avatar
robsc501
Hi There,
I thought I was the only one who used windex.& paper towels. Works for me,but I do it every 2 or 3 days.
robsc501
Old Aug 30, 2010 | 08:02 PM
pendan's Avatar
pendan
Evil Twin,
Did the BKF today and the results were UNBELIEVABLE! I am all in! Thank you for the key! This is the BEST idea for a cure and is low, low cost and trouble!
P
Old Aug 30, 2010 | 09:35 PM
Boulty1961's Avatar
Boulty1961
I will be getting BKF the next time I am at the store so I can give it a try.
I have been using Turtle Wax Chrome Polish and it works great.
Post up some pictures.
Yes, I am twisted but I like it when the tips shine.
With No Flash
With Flash
Old Aug 31, 2010 | 12:13 PM
bighank's Avatar
bighank
Default Had SS on my 99 vert but traded up to Chrome
Dealer had several brand new exhausts that were removed on delivery and replaced with custom exhausts. I paid labor and he gave me the exhausts (Mufflers and tail pipes) for no charge. Simply use an old cotton towel when I wash the car and it removes the carbon at the tip ends. No exotic exhaust tip cleaners needed.
BIGHANK
Old Aug 31, 2010 | 06:44 PM
  #33
vette54728702's Avatar
vette54728702
Excellent info....thanks for sharing!
Where can I find Rejex?
Old Aug 31, 2010 | 08:16 PM
  #34
had2have-it's Avatar
had2have-it
I found some all purpose polish/cleaner in a motorcycle shop called "Boms Away", it will do aluminum, chrome, stainless, copper and more. Its quick, easy and leaves the best finish I have ever gotten from a metal polish/cleaner...google it.
Old Aug 31, 2010 | 08:50 PM
  #35
dklowrider's Avatar
dklowrider
i found out that a pcv oil catch can all but eliminates this problem. i used to wipe the black junk running out of the pipes almost daily. it does take a little while for previous contamination to clear out.
