New Shocks?
Old Jul 23, 2010 | 03:14 PM
vettenlady's Avatar
vettenlady
Default New Shocks?
Hi Fellow Vetters,
I cant believe its been six months since I've visited the forum.:o
Anyway, upon inspection of a leaking tire, I was told that my shocks are leaking, all four, but more so, the front ones.
She has 44K miles, but our roads are sometimes a little rough. My ride hasn't changed much, still pretty smooth, but then I've noticed that I can feel a little road vibration in the steering wheel, and, maybe, more noticeable bumpiness on pavement.
Are they truly wearing? And if they need replacement, what should they be replaced with? Does the MRC come into play with getting new shocks? I was quoted nearly $600 for all four, but I'm assuming that they would be standard shocks, and it isn't a Chevy dealership. Do the C5's come with standard shocks or should I go to a Chevy dealership?
I could really use some input about this.
Thanks,
Old Jul 23, 2010 | 03:37 PM
cammedvette's Avatar
cammedvette
Just recently visited Mr. Gene Culley at GM parts house and purchased some C6 Zo6 Shocks in the $240.00 range. Put them on myself, not really too hard to do if you are willing to do it yourself. Not sure what a shop would charge you to install?? These shock were definitely a marked improvement over the stock shocks.
Old Jul 23, 2010 | 04:42 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
C6Z06 shocks are next on my list even though my stock shocks only have 24K miles on them...$240 is a great price
Old Jul 23, 2010 | 05:09 PM
Kale's Avatar
Kale
MRC? You mean the magnetic shocks? You can't just throw new shocks in and drive off. The system will flip its lid if you take the shocks out.
You need to either replace them with same $2500+ or find someone who has experience in removing the F55 code from the computer. It's only about a 20 minute job, but requires a tech II and know how
Old Jul 23, 2010 | 05:19 PM
MagRedConv's Avatar
MagRedConv
You were quoted all 4 shocks for $600? Jump on it.
Old Jul 23, 2010 | 05:28 PM
Blew by you's Avatar
Blew by you
It depends on wether or not you have the adjustable suspension or not if you do, you need to have shock simulators installed, if you buy aftermarket shocks. If you buy stock shocks, for a Vette with magnetic ride adjust, GOD HELP YOU! they cost thousands for a full set.
Old Jul 23, 2010 | 05:56 PM
Kale's Avatar
Kale
No way $600 for magnetic shocks. My guess is the shop is ignorant of the F55 system and would be putting on some monroes or gabriels or something.
Then she would be driving off with SERVICE RIDE CONTROL MAX SPEED 80 MPH SHOCKS INOPERABLE DING DING DING DING DING!
I would also like to point out that shock simulators do not work with the magnetic F55 system. Only with the older systems.
Old Jul 23, 2010 | 06:01 PM
Blew by you
I have an 02 and was told by a reputable Corvette shop the simulators would work, and i could throw on some Bilsteins for less than $500.00 plus the simulators. Is this true simulators work on 02's. thanks KALE
Old Jul 23, 2010 | 06:04 PM
Kale's Avatar
Kale
Should be fine. It's just the 03-04 magnetic shocks they can't fool. They are much pickier.
Old Jul 23, 2010 | 06:10 PM
Blew by you
Thanks man i was just inquiring with, West Coast Corvette's about doing this it's nice to know i can dodge the $2500.00 bullet, thanks again for the info kale.
Old Jul 27, 2010 | 06:40 PM
vettenlady's Avatar
vettenlady
Default New shocks?
Hi,
Now I am confused. I dont know whether I have the magnetic shocks or not. I thought I had read somewhere that all 03's have them. Maybe I am thinking, instead of ride adjustments. If I had magnetics, how would I be able to tell?
Before you all start rolling your eyes, I am a 70-ish female vette owner. What do I know?
Old Jul 27, 2010 | 06:52 PM
03WhiteConv's Avatar
03WhiteConv
Originally Posted by vettenlady
Hi,
Look on the console next to the traction control button, there will be a ride selector switch there if you have it.
Old Jul 27, 2010 | 07:46 PM
8VETTE7's Avatar
8VETTE7
Hi,
You can look on the inside of the glove box door and look for RPO code F55. If you have that RPO then it is Magnetic Ride Control. From a dealer you you are probably looking at a cost of $3600 or more. Each shock lists at about $900. From Gene Culley (GMPARTSHOUSE.COM)you can buy them for about $600 each. Significant savings but for my money STILL WAY WAY too much for shocks no matter how good they are claimed to be.
If you can find some one with a TECH II you can bypass the F55 option in the car and then run C6Z06 shocks which you can buy from Gene at $240 FOR ALL 4 shocks.
Here is the info about bypassing the F55 option with a Tech II:
1. Hook up your Tech 2 (Driver's footwell), turn the car ON, make sure the module in the left rear storage compartment (pull back the velcro lining on the front of the compartment) is plugged in. DO NOT UNPLUG THIS MODULE
2. Now use the Tech 2 to delete the F45 option ( F55 option does not appear on the Tech 2 menu screen - SO - DELETE THE F45 OPTION
(use the screen captures - steps 2-14)
3. Save the new configuration
4. DO NOT TURN THE CAR OFF DO NOT REMOVE THE TECH 2 Go to the module in the rear of the car, unplug the GRAY connector - IT IS THE WIDEST ONE - leave the other 1 (F/45) or 2 (F/55) plugged in.
5. Turn off the car but LEAVE THE TECH 2 PLUGGED IN
6. Remove remaining plugs from module in the rear of the car - Never plug them back in again, if you do the F/45 turns on automatically.
7. Now the moment of TRUTH - Turn the car on and verify that the dreaded - MAX SPEED 80 MPH - is gone. This message was only present if you had already disconnected the shock sensors. Some people have had to disconnect their battery to allow the computer to reset to remove this message, but I would confirm with the Tech II that the F/45 was actually deleted first and if not reconnect everything and start again with step 1.
8. Unplug the Tech 2 - Get in the car and take it for a ride. Smile as you pass the DREADED 80 MPH.
With these instructions in their hands even the most inexperienced tech can do this. It took mine 5 minutes and they charged me $25. I would have spent much more time and effort getting and installing resistors.
If you haven't already changed your shocks drive home carefully as the shocks become very soft, not dangerous but as GM advises keep it under 80MPH.
You may get some posters that will tell you can use "simulators or resistors to fool the system. Thise work on the earlier F45 suspension for the 2002 and earlier cars. It does not work for the F55 suspension.
Old Jul 27, 2010 | 08:49 PM
The Magnetic Selective Ride shocks are damn expensive. If you have those, get them tuned out and then go with either the C6 Z06 shocks or a set of Bilstein Sports.
Old Jul 27, 2010 | 09:36 PM
zipity's Avatar
zipity
St. Jude Donor '10
All 2003 Anniversary Editions Corvettes had the Magnetic Shocks, they were optional on the 2003 coupes and convertibles, not available on the Z06.
Old Jul 27, 2010 | 09:47 PM
Joy of 6's Avatar
Joy of 6
Gail,
Hopefully you can find a reference for a local mechanic to help you out (or a forum member). If not, come on down to Vancouver as we have Tom Wong here who is a magician with Corvettes. Could even put you up here for a few nights while you visit (No hustle here, I'm married)
Old Jul 27, 2010 | 11:55 PM
jon c's Avatar
jon c
I went with the C6 Z shocks and really like them of course I went with the Z51 swaybars as well very nice combo
To New Shocks?
Old Jul 29, 2010 | 03:29 PM
vettenlady's Avatar
vettenlady
Hey,
Thanks for the info on whether I have magnetics or not. Yes, I have the Anniversary 03, and I have a selector on the console with the choice of "Tour" or "Sport". However, in the glove compartment, on the little sticker for parts ID #'s, I didnt see any F55.
So....do I have them?
Old Jul 29, 2010 | 07:29 PM
01magnetic01's Avatar
01magnetic01
Yep....you've got em...
Old Jul 30, 2010 | 06:15 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
