Interchangable ABS Modules???
Old Oct 29, 2011 | 10:47 PM
billyward's Avatar
billyward
from what i under stand the only module and pump for front mounted, 4 wheel abs, with active handleing, and automatic transmission is module #09376711 new #19244084 the pump # is 10417038 that is all that the sn of the cars from 1998 -2000 will fit. one unit is the only thing and it has a V. the M will not work. i have been trying to fix this car for all most 2 years, if some one has a pump and module that matches the above please contack me. 803-424-0865! leave a # where you can be reached. thanks.
Old Oct 29, 2011 | 11:02 PM
billyward's Avatar
billyward
Default 1998 corvette with active handleing
Originally Posted by madmatt9471
Add an extra "4" = 19244085
Thanks,Matt
matt you think this 19244085 will fit my car. the # i have is 19244084 which is a new # is it the same as the 85. call me when you can 803 424 0865 i need help with these #`s. thanks!
Old Oct 29, 2011 | 11:06 PM
billyward's Avatar
billyward
this gm part # stuff is confuseing.
Old Oct 29, 2011 | 11:07 PM
billyward's Avatar
billyward
i am about to part this car out. i ain`t paying no thousand dollars to take that lite out.
Old Oct 30, 2011 | 10:16 PM
billyward's Avatar
billyward
Default 1998 corvette abs pump and module
Thanks,Matt
can some body that has the oem delco part in their 1998 corvette with the abs unit in front with active handleing and 4 wheel abs lift the hood and get the module and the pump # and put it in here to help me clear up this 2 year nite mare! my pump and module was stolen before i bought the car so i don`t know what the #`s were except what the chevrolet dealers tell me. thanks!!
Old Oct 31, 2011 | 07:32 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I tried to call today, but no NON-active handling module will work in a Active Handling equipped Vette.
BUT all 98-2000 A?H modules will be interchangeable - I don't have a list but I can look on my computers parts manual to see the original '98's module number and ABS part number - just let me know!
I had major surgery on my shoulder so I am at home - just let me know!
Thanks,Matt
Old Oct 31, 2011 | 09:01 PM
billyward's Avatar
billyward
Default yes i need the #`s
Thanks,Matt
i really need those #`s badly. thanks!
Old Oct 31, 2011 | 09:28 PM
madmatt9471
JL4 Option Active Handling
The PDF File for part numbers is: Mounted in the front OR back
Module: 9376711
ABS Pump: 10417038
I hope this helps, now you can do what I did and call a GM dealership and talk to a rep in the parts department and "ASK" for them to look up the number and see if it is available, it will not be, so let them know you are hunting a used one so can you "PLEASE" have any and "ALL" succeeding or previous numbers for the part so you ca do a thurough used part search - this will work it did for me!
Thanks,Matt
Old Mar 3, 2016 | 05:42 PM
mooradian7145's Avatar
mooradian7145
1st Gear
Default "m"
"M" Version means it DOES NOT have Active Handling
"V" Version means it has Active Handling
"M" Version #09356961 is on my 2000 Corvette
I've been told that the interchangeable 3 is 16257049
I'm looking to replace or repair mine it is defective.
If you know of one available I would appreciate it.
Originally Posted by AlsC5
My ABS Control Module: 1998 C5
ABS-5/TCS/MSVA2
DELCO ELECTRONICS
MODEL: 16257049
LARGE "M" ON RIGHT SIDE OF NUMBERS
Can I exchange mine with this model?
2000 C5
ABS-5/tcs/msva
Delphi D
Model : 0935691
I has a large M on the right side of the numbers
Will this work or am I out of luck?
Old Feb 18, 2021 | 09:35 PM
albo$'s Avatar
albo$
1st Gear
Whis your Module located?
In the front or the rear?
Thanks,Matt
ebcm looking for one for 2000 vett model number 19244085. I see u know alot about these thanks
