Turn signal bulbs
Old 08-07-2010, 04:04 PM
chipsteak
chipsteak's Avatar
Default Turn signal bulbs
I am replacing turn signal bulbs like crazy in my 98 Coupe. I have had both assemblies replaced and I am still replacing bulbs every couple hundred miles. Is it the LOUSY PA highways rattling the daylights out of them? I do think IEDs are being placed every 200 yards on our roads.
Old 08-07-2010, 05:02 PM
Oldvetter
Oldvetter's Avatar
you probably have a crack in your lens. Water is breaking the bulbs. It comes from too much heat. You can seal it, using windshield sealer.
Old 08-07-2010, 05:07 PM
Mr.Bill
Mr.Bill's Avatar
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I believe he said he already replaced the housings and still blows bulbs.
Old 08-07-2010, 05:11 PM
Oldvetter
Oldvetter's Avatar
I thought he might have meant just the bulb socket housings.
Old 08-07-2010, 05:12 PM
JW Motorsports
Banned Scam/Spammer
JW Motorsports's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Hmm usually it's the cracked housings, but you already replaced those.
How do the sockets look? What kind of bulbs are you using?
Old 08-07-2010, 08:40 PM
VetteSiNz
VetteSiNz's Avatar
you must have a bad socket - happens to me.
Old 08-08-2010, 03:16 AM
DeeGee
DeeGee's Avatar
If the housings are sound the sockets must be corroded.
You could try pulling the A2 fuse to kill the DRLs and see if they last longer. With no DRLs the bulbs are only acting as turn signals so the thermal load is less.
Terry M. (08-30-2016)
To Turn signal bulbs
Quick Reply: Turn signal bulbs
