[Z06] alignment issues
Old Aug 10, 2010 | 10:33 PM
91 monster Z's Avatar
91 monster Z
Default alignment issues
Hello I have a issue with alignment or something. The Z as 66,000 plus miles just had car lowered 1/4 or so new invos on back and f1 on front that are going to be replaced buy end of the week. Pick the car up on Monday from the tuner and drove home about 150 miles away. The car was all over the place as you would imagine it needed a alignment. So that what i did this morning. Well I got a call about 12:30 and he said that they had aligned the car but the thing was driveing like it was on ice. the front of the car will just dart from white line to center strip and back again with out hardly moving the wheel right or left. Yes its grabing the grove of the hwy but not like you would think it should act like. It would start dart back an forth on a straight line till you got off the gas and let the car slow down with out hiting the brakes. Any insight would greatly apprecated.
Russell
91 Polo Green ZR-1 #1501
03 TR Z06
Old Aug 11, 2010 | 07:16 AM
AU N EGL's Avatar
AU N EGL
the older F1s in front are part of the problem.
Need the new and same tires on front then do an alignment
Old Aug 11, 2010 | 08:34 AM
91 monster Z
Thank you have already order the front 2 tires just waiting to come in.
Have a couple of buddies that said same thing just wanted to see if there might have been something else up with it.
Thank you Russell
Old Aug 11, 2010 | 11:38 AM
AU N EGL's Avatar
AU N EGL
Check the tie rods to see if they are tight.
But normally different tires even different age of the same tire will cause what you are describing
To alignment issues
