Gas leak
Old Aug 17, 2010 | 11:52 PM
Gochristian1's Avatar
Gochristian1
4th Gear
Default Gas leak
I had about less than 1/4 from last night, I start the car I receive a check Gage red light. Only Gage not working is fuel. I start the car again and now it's empty. The car said reserve fuel. I went to gas station and put in 20 dollars of premium and got 3/4 with a range of 170
Than through out the day it seems everytime I started the car I was one line less in my fuel Gage. What do you think can be the problem
One day and about the same I usually drive daily I consumed three days of fuel
Old Aug 17, 2010 | 11:56 PM
Jet-Jock's Avatar
Jet-Jock
Corrosion on the sender contacts. Put Techron into the fuel system and use it regularly. Chevron and Texaco Supreme's have Techron in them.
Old Aug 18, 2010 | 02:48 PM
Gochristian1
4th Gear
So does that mean I don't have an gas or the sender is broken
Old Aug 18, 2010 | 02:51 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
It seems to be a common problem with the vettes.Use Techron a few times a year and you shuld be ok.
Old Aug 18, 2010 | 02:56 PM
Jet-Jock's Avatar
Jet-Jock
The sender has exposed contacts. They become corroded when not treated with Techron, and will generate false or zero readings.
Stop by your local auto parts store and pickup a bottle. Add according to the directions. From this point on, either use Chevron or Texaco, or regularly add in Techron to your favorite gasoline.
I'd see how it does as a few applications, but definitely fill it up so you know where you are starting from.
To Gas leak
