Speed bump scraping
Old Aug 25, 2010 | 09:26 PM
jww193's Avatar
jww193
Default Speed bump scraping
Hi all - I've seen lots of posts about lowering a vet, has anyone gone the other way and raised it a few inches? Could that be done? The apron on my driveway is killing me as well as most of the speed bumps (mountains really!) at work......
Old Aug 25, 2010 | 09:30 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
I hear ya ! That air dam sound goes right through ya !
Old Aug 25, 2010 | 09:35 PM
BobAruba's Avatar
BobAruba
A vendor on here is selling a new product called Fangs... a hard polymer plastic cover for the front frame rails.
Good luck.
Bob
Old Aug 25, 2010 | 09:43 PM
CatCam's Avatar
CatCam
Good luck.
Bob
Take it on an angle.....and get ya some FANGS!! They work!
Old Aug 26, 2010 | 02:31 AM
Jistari's Avatar
Jistari
The "at an angle" thing is good for inclines where the wheels lift the car as they roll up. Wont help for speed bumps. problem is right behind front wheels.
I would consider raising it a tad of thats where you are scraping. You could put the rail frame savers on, but that still has you rubbing over them if thats what is happening.
If its an area that you are forced to transit every day, may just want to bite the bullet and raise it a bit and be done with it.
Good luck.
Old Aug 26, 2010 | 03:13 AM
JETZ's Avatar
JETZ
'A few inches'?
I think you really want a truck!
As usual, an other over reaction over the front spoiler doing what it was designed to do, flex, and scrape upon contact. Nothing is being damaged, and easy, and cheap to replace. Do it a few more times, and it will get shorter!
Old Aug 26, 2010 | 05:54 AM
Jistari's Avatar
Jistari
Originally Posted by JETZ
'A few inches'?
Dude, you may be right but....you were there?
If its the front, yup no biggie....if its the rockers....well, better you than me
Old Aug 26, 2010 | 06:25 AM
JETZ's Avatar
JETZ
No problems here!
Old Aug 26, 2010 | 06:30 AM
4SFED Z's Avatar
4SFED Z
Look up Fat Daddys, Fat Mammas, ect. Also invest in Frame savers. I picked up both from A&A Corvette
Old Aug 26, 2010 | 06:47 AM
killain's Avatar
killain
Oldtimer
Default The never ending scraping sound. . .
There ISN'T a thing you can do about the scraping of the air dam. I've tried everything. No dealership has a clue. In the owners manual it even states that the scraping of the air dam is a normal condition, What . . . ?
Old Aug 26, 2010 | 11:55 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
No problems here!
I'm with you Frank...
Toque
Old Aug 26, 2010 | 05:17 PM
REDEVIL's Avatar
REDEVIL
No problems here!
My car used to be that low, but when I moved offices for work there are HUGE speed bumps going into the parking structure. Let's just say that your car would be high-centered if you attempted to negotiate one... I had to raise my car back up to stock ride level, and after 8 months, I kinda like it that way. My car is not a daily driver, but I didn't like the fact that I couldn't drive it to work even if I wanted to. I love the looks of lowered C5's but the practicality issues is what made me go back to stock. BTW, I have the front rollers and frame rail savers, and grinding over speed bumps, even with these installed, is not something you want to do daily.
Old Aug 26, 2010 | 06:24 PM
C50Bob's Avatar
C50Bob
I highly recommend raising your C5. The previous owner had lowered the front as much as possible by loosening the front ride height adjusters. Measured distance from ground to fender lip was 26.75”. Looked good, but was unacceptable over bumps and dips. I am very happy with going the other way. Measured distance is now 27.5”. Raising a little more to 27.75” may be better yet. The front end will still be lower than the rear. Turn the adjustors CLOCKWISE to raise the car. One full turn (revolution) produces about 1/16" change in height. Make sure to unload the composite spring before using a 10mm wrench to adjust. WD-40 may also be required.
My notes: Loosen lugs, jack car, remove rim, unload composite leaf spring by jacking on spring end (as close to rotor as possible). Apply WD-40. Wait. Adjust & count turns (the rubber bushing turns with the bolt). Turning clockwise raises the spring (which also raises the car) and reduces the exposed threads on the adjusting bolt. The little spring clip is non-functional. Here is a good link with pictures:
http://www.frankhunt.com/FRANK/hobbi...5_Lowering.htm
One misleading picture in this link is the one labeled “Front After”. The picture is actually a rear adjuster. Just use the picture labeled “Front Before” as your guide.
Regards,
Bob
Old Aug 26, 2010 | 07:39 PM
mfastert's Avatar
mfastert
I don't scrape on anything either and I'm slammed. I go over speed bumps and humps with no problem. Speed humps and steep driveways must be taken at an angle though.
Old Aug 29, 2010 | 11:21 PM
jww193's Avatar
jww193
Default thanks for the suggestions
Hi all - thanks for the suggestions. I'm not scraping the rockers so it's not quite that bad, but it is really annoying, especially my driveway. I have to attack at at least a 45 degree angle (big hump) to get minimal frame rail scrape. I'm going to look at the adjuster bolts and see where they are set.
Question; If I adjust the bolts I need to get the car aligned?
Old Aug 29, 2010 | 11:33 PM
mfastert's Avatar
mfastert
I'd say yes if it's a big change. I turned mine one turn and didn't bother.
Old Sep 11, 2010 | 10:30 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Hey,
I read your post about scraping up and down driveways, going over speed bumps and pulling too far forward and hitting parking blocks. The Fangs are a must have for any corvette especially a lowered one. The Fangs are availble in black or white with no drilling or modification to the C5 corvette skid bars. Check out the Fangs at http://www.saccitycorvette.com/Fangs.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
To Speed bump scraping
Old Sep 15, 2010 | 05:22 PM
vettespur's Avatar
vettespur
Just ordered - looks like a good product.
Brent
Old Sep 15, 2010 | 06:05 PM
hotwheels57's Avatar
hotwheels57
It will self level after a few trips over the speed bumps and curbs.
It serves as a reminder that if you don't slow down and/or change your approach angle, the next awful noise you'll hear is your rockers being scraped...
Old Sep 15, 2010 | 09:18 PM
Rohan's Avatar
Rohan
Yeah, and it'll look something like this.
