Belt chirping
Old Aug 29, 2010 | 06:28 PM
ignatkor's Avatar
ignatkor
Default Belt chirping
Had this squeaking/chirping sound 3 months ago, back then I went ahead and replaced both belts (since the vert had 85000 miles on the clock) that seemed to fix the problem. Yesterday heard loud chirping sound ,obviously coming from belts/pulleys. It only squeaks when I put my foot on the accelerator, even when I do it real easy. when the car just idling there is no sound at all. Can't be the belts since they are basically brand new, no signs of wear and tear, no cracks, etc. so I'm guessing it must be one of the pulleys. I'm going to Chevy dealership in a few days, but I thought if it is something relatively simple I could do myself. Anybody had a similar problem?
Old Aug 29, 2010 | 06:37 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Take a good look at the harmonic balancer on the crankshaft and see if its wobbling. If so, that will need some attention right away.
Old Aug 29, 2010 | 08:22 PM
ignatkor's Avatar
ignatkor
Thanks! I looked and it did seem a bit wobbly. The strange thing though is that even after I turn the car off the chirping continues for another 10-15 sec. I can still hear it while the belts and pulleys not even moving anymore.
Old Aug 29, 2010 | 09:14 PM
dgrant3830's Avatar
dgrant3830
HVAC Blower motor? Radiator fan motor's?
Old Aug 29, 2010 | 10:27 PM
corvettedaddy11's Avatar
corvettedaddy11
That chirping is a PITA,changeing belts cured mine!!
Old Aug 29, 2010 | 10:59 PM
tricep's Avatar
tricep
St. Jude Donor '09
Upper tensioner
Lower tensioner
Idler
Old Aug 29, 2010 | 11:07 PM
dgrant3830's Avatar
dgrant3830
Originally Posted by tricep
Upper tensioner
Lower tensioner
Idler
No offense but he said it was still chirping after shutting down the engine so it couldn't possibly be an tensioner, at least I don't think so. I could be wrong of course.
Old Aug 30, 2010 | 02:07 AM
ignatkor's Avatar
ignatkor
I certainly appreciate you suggestions, it does sound like it's coming from either belts or pulleys. I'm going to call dealership this morning. My dilemma now is that my local dealership has only one mechanic who works on vettes and is busy all the time, so it will probably be a few days(or even weeks) before I get it looked at. The alternative would be to take it to a local car shop(with a certified mechanic ) and have him look at the car today. I wouldn't think twice if it wasn't my DD but it seems like it might be relatively simple problem that any experienced mechanic could figure out.
Another option is a corvette shop which is 50 miles away from me and charges insane rates like 150$hr.
Old Aug 30, 2010 | 07:14 AM
dgrant3830's Avatar
dgrant3830
Well, at least manually spin the radiator fans and see if they squeak. Try shutting down the HVAC while your engine is still on and see if the squeak goes away. The idlers have no spinning parts when the engine is off to the best of my knowledge and I can't think of anything other than mentioned that would be related after its shut down but still squeaking.
Old Aug 30, 2010 | 02:01 PM
ignatkor's Avatar
ignatkor
Well I just got a call from my local automotive, it was serpentine belt tensioner and idler pulley that needed to be replaced.
Old Aug 30, 2010 | 02:10 PM
LaMagred02's Avatar
LaMagred02
are they changing them?
Old Aug 30, 2010 | 04:39 PM
ignatkor's Avatar
ignatkor
Yes they are
To Belt chirping
