*sigh another broken valve spring
Old Sep 3, 2010 | 01:26 AM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Ever find out what springs are on the car? Like ColeTrain'sC5 said the springs should be yellow if it is stock.
Old Sep 4, 2010 | 09:26 AM
swollix's Avatar
swollix
no clue...
Old Sep 4, 2010 | 03:11 PM
tricep's Avatar
tricep
St. Jude Donor '09
Uhhhhhhhhhhhhhhhh....
I can tell you what you'll probably be dealing with in the long run, but my book isn't completed yet.
Old Sep 4, 2010 | 04:24 PM
swollix's Avatar
swollix
As far as broken parts?
Old Sep 10, 2010 | 01:03 AM
swollix's Avatar
swollix
Another $1,000 later and car runs again! Here is the damage:
Old Sep 10, 2010 | 01:26 AM
0331MARINE's Avatar
0331MARINE
From the first picture the springs look like stock LS1 springs. Could by why it broke....
Old Sep 10, 2010 | 04:30 AM
tricep's Avatar
tricep
St. Jude Donor '09
That is not what a 2002 stock valve spring looks like. The LS6 valve spring in a 2002 was yellow.
If Photobucket wasn't dead in the water right now, I'd post up. Didn't matter anyway, so I guess there's no point.
The 2004 LS6 spring was a brown-copperish kind of color.
I'm not sure why yours is black like that. Either it's covered with oil, or it's from an LS1.
Old Sep 10, 2010 | 09:01 AM
swollix's Avatar
swollix
I have no clue guys.. They are all a dark metal color with some kind of faded paint markings on them. I am only the 3rd owner of this car, 09/01 build date.
Old Sep 10, 2010 | 09:30 AM
TraceZ's Avatar
TraceZ
Can you get a casting number off one of the heads?
Maybe one of the first two owners had a problem and replaced the heads.
Old Sep 10, 2010 | 05:00 PM
Z06Electron's Avatar
Z06Electron
Yup, looks like you got lied to an screwed here.
Old Sep 10, 2010 | 05:02 PM
Z06Electron
My vote is this was a H/C car that was put back to stock, and the heads were replaced with much cheaper LS1 castings and thrown back together for sale. I WOULD NOT run the car like that. You'll just run into the exact same problem again and again and again.
Old Sep 10, 2010 | 08:44 PM
swollix's Avatar
swollix
Heads are 243 casted... Car put down 375/338 so all the power is there.
Old Sep 11, 2010 | 12:01 AM
  #33
tricep's Avatar
tricep
St. Jude Donor '09
Here's a pic of an LS6 2002 stock OEM broke-*** valve spring.
Old Sep 11, 2010 | 12:08 AM
  #34
Z06Electron
338 is a really low torque number in relation to the HP, something going on there.
Old Sep 11, 2010 | 08:40 AM
  #35
Pete W's Avatar
Pete W
Did you get all of the valve springs replaced, or......? If you did what kind did you buy? Good luck.
Old Sep 11, 2010 | 10:20 AM
  #36
swollix's Avatar
swollix
replaced them all with COMP 918's.
Old Sep 12, 2010 | 12:28 AM
  #37
Pete W's Avatar
Pete W
You'll be fine with those then. They were very good to me when I had the stock heads on. They saw 7k rpm (aftermarket cam motor) and they never had an issue. Good to hear that. I am guessing you will be good to go for another 100k miles.
