*sigh another broken valve spring
Old Aug 30, 2010 | 12:10 AM
swollix's Avatar
swollix
Default *sigh another broken valve spring
02' Z06, with 90k miles. I was leaving a red light and it gave out at around 30 mph. I felt a huge loss in power and heard a tapping noise from the motor so I shut the engine off and coasted to a parking lot. I took off the valve covers and this is what I found:
What should I do next?
Old Aug 30, 2010 | 09:05 AM
7thgeneration's Avatar
7thgeneration
As Barney Fife would say..."NIP IT ! NIP IT IN THE BUD " ! I would replace them all as a set and be done with it. Especially since this isn't the first. Good luck !
Old Aug 30, 2010 | 09:24 AM
swollix's Avatar
swollix
From the picture can you tell if any other damage has been done?
Old Aug 30, 2010 | 09:31 AM
7thgeneration
Pretty hard to tell from a pic but the less it was driven afterwards the better. A tow from the parking lot would have been best.
Old Aug 30, 2010 | 10:02 AM
swollix's Avatar
swollix
That's what I did. Did not restart the car.
Old Aug 30, 2010 | 10:25 AM
itzza427's Avatar
itzza427
I would go the whole set route as well!! I'd post this in the tech/performance section,,and get recommendations as to brands. I read performance,,but only have heard of ones like Comp Cams beehive springs,,but I know there are others that are highly regarded!! Do them all and get some peace of mind!!
Old Aug 30, 2010 | 10:31 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
At 90k and this is not the first one time for a new set of springs if it was mine
Old Aug 30, 2010 | 10:32 AM
TraceZ's Avatar
TraceZ
It looks like the end of the valve is no longer in the center of the spring.
I'd assume the valve went into the cylinder bore and interfered with the piston. Until you get the head off you won't know how ugly it got.
Cross your fingers, hopefully the damage is minimal.
Old Aug 30, 2010 | 12:45 PM
swollix's Avatar
swollix
The end of the valve is about halfway down the center of the collapsed spring. I guess I need a compression test huh?
Old Aug 30, 2010 | 12:48 PM
02*C5's Avatar
02*C5
A set of PAC 1518 and be done with her.
Old Aug 30, 2010 | 12:52 PM
swollix's Avatar
swollix
How are the PAC 1218 or COMP 918's?
Old Aug 30, 2010 | 01:35 PM
TraceZ's Avatar
TraceZ
Don't bother with a compression test. There is no way that cylinder will pass.
Just pull the cylinder heads and assess the damage. See if the cylinder wall is damaged, and inspect the top of the piston for damage. At a bare minimum you'll need to have a shop check the head out before installing a new valve and new valve springs all around.
EDIT---
If you put a long nose plyers on the end of the valve can you pull it closed? If so, maybe a compression test is a good idea...
Old Aug 30, 2010 | 01:42 PM
ColeTrain'sC5's Avatar
ColeTrain'sC5
I've got duals in mine, far less likely that that will happen. Sucks dude. From the pick it looks like the spring is off center from the break and not the pushrod. I'd definatly check it all out before you put it back together
Old Aug 30, 2010 | 01:45 PM
swollix's Avatar
swollix
EDIT---
Haven't tried I will when I get home from work...
I thought Z06 springs were supposed to be yellow from the factory???
Old Aug 30, 2010 | 03:03 PM
Dave68's Avatar
Dave68
Are you running the original cam? A mismatched cam/spring combo will result in broken springs. That's why I ask.
Old Aug 31, 2010 | 10:38 AM
swollix's Avatar
swollix
Car is stock....
Old Aug 31, 2010 | 11:29 AM
ColeTrain'sC5
Yes i believe Z06 springs are supposed to be yellow
To *sigh another broken valve spring
Old Aug 31, 2010 | 01:30 PM
dragon84's Avatar
dragon84
OK so if I were going to replace mine which is better? I know this is an opinion question that has been addressed several times before but the search function is much help.
I see a pretty good price difference from:
PAC 1518 for $356.00
Comp 918 for $169.00
Yellow GM LS6 replacement springs for $79.00
Any constructive feedback on these three options?
I'm planning on swapping them myself. I have never tried but it doesn't look all that hard.
Thanks for the input
Tom
Old Aug 31, 2010 | 01:40 PM
zeevette's Avatar
zeevette
Don't skimp on replacement springs.
Old Sep 3, 2010 | 01:01 AM
swollix's Avatar
swollix
Got a call from the shop, valve is definitely bent.
