Help! Got the wrong headers
Old Sep 4, 2010 | 07:06 PM
khafe458's Avatar
khafe458
Default Help! Got the wrong headers
Hello,
I went up to Carlisle and picked up a new set of American Racing headers but the problem is they gave me ones for an 2001-2004 and I have a 2000. The air tubes dont fit and there is no fitting for the dipstick shaft. I tried to search on how to modify it but didnt really get anything. I spent all day today putting them on and didnt figure out I got the wrong ones till I was near the end, so I really dont want to have to take them off again.
Has anyone modified 2001-2004 headers to fit a 2000? How is it done?
Thanks!
Kevin
Old Sep 4, 2010 | 07:25 PM
Russ K's Avatar
Russ K
You need to purchase a 2001 dipstick, tube & bolt, and a 2001 right side A.I.R tube.
Russ Kemp
Old Sep 4, 2010 | 07:58 PM
corvettedaddy11's Avatar
corvettedaddy11
I bought 01 headers for my 99 and cut and rewelded smog tube no big deal, I bought full length headers of craigslist for $150.00 (Stainless works) I made them fit for $150.00!!Had to drive 4 hours to get them !
Old Sep 4, 2010 | 08:00 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Originally Posted by khafe458
Hello,
Thanks!
Kevin
I would see if they will pickup shipping and return them for the correct headers.
Old Sep 4, 2010 | 08:05 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
You either need the 01+ air tube for the passenger side or use block off plates and have the Air system tuned out. I actually bent my passenger side tube and made it work, but it was tough and I don't suggest trying it.
The dipstick can easily be bent to fit. You will have to be creative when mounting it.
Old Sep 5, 2010 | 10:39 AM
khafe458's Avatar
khafe458
Thanks everyone! Anyone got a part number for an 01 air tube?
Old Sep 5, 2010 | 11:16 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
12561494???
http://www.ls1howto.com/index.php?article=29
Old Sep 5, 2010 | 11:37 AM
jrose7004's Avatar
jrose7004
I'll bet that they'll cheerfully exchange them for the right ones.
Old Sep 5, 2010 | 03:21 PM
khafe458's Avatar
khafe458
I would think so. But don't really feel like taking it back off the car now if I dont have to
Old Sep 5, 2010 | 03:22 PM
khafe458's Avatar
khafe458
Originally Posted by Quick Silver Z
Coming up empty with that search but thanks for the help!
What if I cut my Air tube for my 2000 and inserted a 6" length of rubber tubing, like is on the drivers side, to get it where I need?
Old Sep 5, 2010 | 03:46 PM
jonnyc's Avatar
jonnyc
that will work for a temperary fix until you can get the correct air tube.if you don't have to worry about smog,i would just get rid of the whole air setup all together and block off the air tubes on the headers.
you can put a WTB add in for sale section.someone probably has one.if not i'm sure Gene will help you out.
Old Sep 5, 2010 | 03:54 PM
khafe458's Avatar
khafe458
Thanks for the advise. I will post a WTB add, but who is Gene?
Old Sep 5, 2010 | 06:27 PM
atmsrus1's Avatar
atmsrus1
Gene is Gene Culley from the GM Parts House. He posts deals every month here on the forum.
Russell
Old Sep 6, 2010 | 09:26 AM
Quick Silver Z
Is this the tube (scroll)?
http://forums.corvetteforum.com/1574561530-post1.html
Old Sep 6, 2010 | 09:35 AM
Quick Silver Z
Meet Gene...
http://www.gmpartshouseusa.com/shopp...&siteid=214638
Old Sep 6, 2010 | 10:20 AM
khafe458's Avatar
khafe458
Yep, that looks to be it.
Sent Gene an email. Thanks for your help!
Old Sep 6, 2010 | 10:32 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Go ahead, it won't hurt anything. All the AIR system wants to do is put air into the exhaust so the PCM doesn't go nuts. Doesn't matter if it's coming through rubber tubing, or aluminum tubing.
Cut the tube where you want it, splice in the rubber tubing, route it away from any heat source, attatch to header. Done.
To Help! Got the wrong headers
Old Sep 6, 2010 | 10:33 AM
Quick Silver Z
I do better with the searching than I do with the installing. Hope it works out for you, keep us posted on your progress.
Old Sep 6, 2010 | 10:50 AM
krzytrain's Avatar
krzytrain
All Aboard!!!
Sorry that is bad luck...... I had a similar situation happen to me. I was at Carlisle and picked up a set of Kooks headers for my 99, went to my buddies house to put them on this weekend, checked and made sure the headers were right and everything was there. Started installing everything (by the way this isnt a easy as it looks to do) Got all the way to the mid pipe and they sent me 2 drivers side pipes All we did was look to see that they were there we didnt pull them out and check to make sure they were right.
Damn the luck on a holiday weekend, no biggie i will be on the phone tomorrow morning to get me a new one sent out over night.
Old Sep 7, 2010 | 09:12 AM
khafe458's Avatar
khafe458
*Update* So after thinking about it, I wanted something to show for all the work I did this weekend so I decided to cut the air tube and put in about an 8" length of rubber tubing. I also made a mount to attach the oil dipstick shaft to the air tube bolt. Both worked perfect, but I think I am still going to get a 01+ airtube and dipstick because its not a clean look but it works.
I had a scary moment though when I went to start it for the first time, I turned the key and click...nothing. My heart sank. I knew it had to be something with the starter since I did have to take it off to get the headers to fit. I was hoping I didnt have to take it back off cause everything would have had to come off. There is minimal room between the headers and starter so I knew it was going to be a b1tch to get to. So after jamming my hand down between the headers and block and started feeling around, I get zapped. My own dumb fault for being in a rush and not disconnecting the battery but it helped me find the problem. I was missing one of the 3 positive cables that go to the starter. After a couple more bloody nuckles and a few more minutes of swearing, it was on. I reconnected the battery and she came right to life.
I will say this, the car should have came with headers from the factory! The sound is simply amazing! I have a mid-america cad-back and it always sounded more exotic then "muscley" but now its got that deep grumble that you want. I can def feel a little bit more get up and go in the seat of the pants but can't wait to get it tuned and get the full potential of these.
The most rewarding thing about the whole project was when I took it for a cruise with my buddy and we pull up to a light next to a bunch of what looked like high school kids in the car. Of course I had the windows down and so did they and the guy sittin in the passanger seat asked me "How much fun is that to drive?" I said "A lot more now" and he asked why. I gave the motor a nice little rev and the car full of high school kids all lost it! They all sarted laughing and cheering and it simply made the whole project that much more enjoyable.
I would like to say thanks to everyone for all you're help through this project, it is apprectiated. I wouldnt have gotten it done if it wasnt for yall.
Thanks again,
Kevin
