problem?
Old Sep 4, 2010 | 08:01 PM
skid/1947's Avatar
skid/1947
Cruising
Default problem?
threw the belt off. it ran pretty hot(pegged)
1. why did the belt(year old) come off
2. what damage can i expect from the overheating.
any thought on this is appreciated.
by the way 1997 coupe 82,000 miles
Old Sep 4, 2010 | 08:12 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
1. why did the belt(year old) come off..You might want to check your bottom pully and see if it wabbles.
2. what damage can i expect from the overheating. Blown Head Gasket, Cracked head or worst.
There you have it
Hope you have no damage. I am surprized you didn't get alerted before it maxed out on the temp, Like lo volts or something.
Old Sep 4, 2010 | 08:28 PM
skid/1947's Avatar
skid/1947
Cruising
i did.
Old Sep 4, 2010 | 08:30 PM
skid/1947's Avatar
skid/1947
Cruising
i think i may have an alt. issue. plus being stupid. on the road now for two months. will have time to check it out then. thanks for the reply.
Old Sep 4, 2010 | 08:37 PM
Mr.Bill's Avatar
Mr.Bill
i did.
Why didn't you stop then?
Old Sep 4, 2010 | 08:52 PM
skid/1947's Avatar
skid/1947
Cruising
i thought stupid would have covered that.
wasn't paying attention until it started to steer hard within sight of my house. had my mind on leaving town and it just got by me. i am usually more in tune with the ride but not this time.
thanks for your reply and interest..will post findings when i get back home. thanks again
Old Sep 5, 2010 | 12:36 AM
egrand333's Avatar
egrand333
When mine started throwing the belt I put on a new tensioner and that fixed the problem.
Old Sep 5, 2010 | 12:59 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Here is a write-up I did that will help you "IF" the balancer has walked forward: Pics to help you see if this is the problem:
http://forums.corvetteforum.com/c5-f...cs-inside.html
Well I caught it in time. I thought my A&A Procharger Bracket was delfecting and making my belt come off and shred -
Well upon closer inspection the outer ring was walking forward and making my belt shred and come off - this time the AC belt was walking off the back too - WOW! It was a close one
Well anyway as you know I had to remove the whole rack and Procharger set-up, wheels and tires, sway bar etc. in order to replace the "BALANCER" Bummer!
My buddy Scott came over and we did it in one day, put everything back together and it was back on the road in the late afternoon - We had to go 60 miles to pick-up a BALANCER and New Bolt from the dealership I had a new seal! AND YES! We did re-pin the crank
I was able to get a brand new BALANCER form GM for $113.00 and the Balancer Bolt for $6.60 - not too bad but just getting parts took an extra 2 hours
Check your balancers out when you can for: Missing Rubber and any walking forward. MINE wasn't even wobbling or vibrating but it was coming off
Anyway onto the pics of the old and new Of course the rack and sway etc on the ground:
Missing Pieces of the RUBBER Ring:
Here you can see just how far it was coming forward and a comparison against the new one:
BRAND NEW - what it looks like and the part number:
Installed:
Could of cost me a lot more if it had come flying off. So check those balancers
Thanks,Matt
Old Sep 5, 2010 | 11:48 AM
skid/1947's Avatar
skid/1947
Cruising
balancer and belt new in november o last year. don't mean its good of course.
To problem?
