Shift knob rattle
Old Sep 7, 2010 | 10:02 AM
Dieseldaveswife's Avatar
Dieseldaveswife
Default Shift **** rattle
As part of putting the car on the road I installed the stock shift **** on the car. I know Dave has other ***** but I couldn't find them. Anyway the shift **** rattles. Did I leave something off when I put it on, or is there a way to fix it?
Thank you in advanced.
Carolyn
Old Sep 7, 2010 | 10:10 AM
Dave68's Avatar
Dave68
Did you reinstall the "key"? Here's my uninstall directions that'll show you what I'm referring to:
http://www.conceptualpolymer.com/corvette_install.htm
I would imagine that not having the key installed would allow the **** to rattle.
Old Sep 7, 2010 | 10:58 AM
Dieseldaveswife
thank you..I did not know about the key. I will look at it again.
Old Sep 7, 2010 | 11:11 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Betting Dave is correct about the Key. Good news is it is much easier to reinstall that it is to take it out......good luck.
Old Sep 7, 2010 | 12:45 PM
Goody's Avatar
Goody
I have the B&M short shifter (newer design) with factory **** and it rattles a wee bit at WOT. Tried all I can to correct it but no matter what it rattles.
Never tried it without the key though.....hmmm.
Took the little pattern cover off = rattles
Wrapped some tape on the threads = rattles.
Added some tape to the cup under the shifter itself = rattles.
Yes the gasket is in place and all bolts are tight.
Drive it without the **** and listen for the rattle then.....hmm, may need to try that myself.
To Shift knob rattle
