01 vs older c5
Old Sep 8, 2010 | 10:06 AM
ignatkor's Avatar
ignatkor
Default 01 vs older c5
I was wandering about the little HP increase that all 01 and newer models received. what does this increase mean in a 1/4 mile, Would I feel any difference at all in acceleration between 01,02,03,04 and older c5 s?
I would appreciate if someone who has had both cars could give me a little comparison. the reason I m asking is because I would like to trade my 01 A4 vert for a manual vette. Someone told me that because of the 10 lb ft difference 01 vert with auto would feel just as fast as older ones with m6, in that case I would rather go for 01-04 m6.
Old Sep 8, 2010 | 10:18 AM
Dave68's Avatar
Dave68
Starting in 01, non-Z06 MN6s had 5 more HP and 25 lbs-ft of torque over 97-00 MN6s (up to 350HP and 375 lb-ft torque). The A4 torque increase was 10 lb-ft, I believe but HP was up by 5 as well.
Old Sep 8, 2010 | 10:44 AM
dougbfresh's Avatar
dougbfresh
The older cars have other potential problems-ask the guys trying to find replacement EBCM for the early cars. Get the newest car you can afford.
OH, and WANDERING and WONDERING are 2 different words.
Old Sep 8, 2010 | 11:09 AM
robsc501's Avatar
robsc501
Hi There,
with dougbfresh
robsc501
Old Sep 8, 2010 | 11:35 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Since the numbers you quoted are flywheel HP and Torque, I'm curious how the transmission makes for a different number? To the best of my knowledge the engines in the manual and auto are identical.
Old Sep 8, 2010 | 12:52 PM
DeBaGo's Avatar
DeBaGo
2000 A4
Horsepower @ RPM - 345 @ 5600
Torque (lbs. ft.) 350 @4400
2001-2004
350 HP @ 5,600 rpm; 360 ft lb
ONLY PLACE I COULD FIND THE NUMBERS THE ORIGINAL POSTER REFERENCED WAS CORVETTE ACTION CENTER.
All other sources (edmunds, motortrend, etc, etc) all stated 5hp/10ftlb increase. It didnt break out the a4/m6 variance either, so I'm not sure where those number came from or are based off of.
I thought the ls6 intake was really the only performance difference in the two "series".
Old Sep 8, 2010 | 12:54 PM
PostShawn's Avatar
PostShawn
I do believe the intake manifold was different due to the LS1 to LS6 change. A lot of the 1997-2000 owners like myself (1999 owner) swap out the intake manifold for a later LS6 one. I got mine off an 02 Corvette. If you were to buy the manifold and then have a shop install it you'd spend about $500 ($300-400 for manifold and $100-150 for labor).
So if you were planning to do something like that you can kind of add that into the reasoning of getting the 01+ vette. If you are thinking of putting on something like a FAST intake manifold then that whole point may be mute to begin with. But for people like me who daily drive the car and race it on average of 1 time a year the LS6 intake was a much cheaper alternative to the FAST intake.
As far as the difference at the track due to the LS1 to LS6 intake manifold swap I have no idea. Air going into the engine is important so I'd imagine it would have an effect but not sure as to how much. Probably something like .05 of a second. Certainly not something like a half a second just due to that.
Old Sep 8, 2010 | 01:26 PM
wca_tim's Avatar
wca_tim
buy the newest one you can afford, period. a few ponies aren't going to make any difference - you're not going to leave it stock anyhow...
Besides, 10 years out, there is probably going to be that much variation between cars just based on wear, tune, etc...
Old Sep 8, 2010 | 01:37 PM
Dave68's Avatar
Dave68
Auto trannies are almost always less efficient.
Old Sep 8, 2010 | 03:08 PM
Indy's Avatar
Indy
I had a 98 M6 with a few bolt-ons. Now a 01 M6 stock (although Bullets are going on in a few days). Honestly, I can't tell a difference in power. Maybe if you drove them one after another. Just look for the right car, whatever the year. And manuals are a lot more fun than autos
Old Sep 8, 2010 | 04:22 PM
Mark C5's Avatar
Mark C5
Again, how does that affect FLYWHEEL numbers? I''l help you out, IT DOESN'T.
Old Sep 8, 2010 | 04:41 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Yes get the best you can afford.....but most of the problems on the earlier models, including the EBCM are fixable.
Old Sep 8, 2010 | 05:01 PM
dougbfresh's Avatar
dougbfresh
Not EASILY, look at the postings lately for guys with early cars w/ EBCM problems. GM no longer makes them, the aftermarket does not repair them-the ONLY options are finding a USED one. For this fact alone I would stay away from the early cars unless it was a REALLY GOOD deal.
The early cars have other issues too-like the expensive Tire Pressure Monitors.
To 01 vs older c5
