Back up lights not working
Old Sep 20, 2010 | 09:09 PM
myredht's Avatar
myredht
Default Back up lights not working
Back up lights do not work while in reverse but flash when setting alarm.
Can anyone help?
Old Sep 20, 2010 | 10:04 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
I believe there's a fuse specific to the reverse function. Pretty sure it's under the dash but i could be wrong.
Old Sep 20, 2010 | 11:00 PM
stainless40cal's Avatar
stainless40cal
I had a fuse on the passanger side if i remember correctly go and took all the lights with it. Check your fuse's....
Old Sep 20, 2010 | 11:17 PM
TN Vette's Avatar
TN Vette
If you have a 6 speed, I bet your reverse switch is out. My reverse lights didn't work when I bought the car. No fuses were blown, but the lights would only work when you set the alarm.
It was a $14 reverse switch.
I searched on here and it seems to be a common issue.
Here is the switch I bought...
http://www.oreillyauto.com/site/c/de...1945&ppt=C0039
Old Sep 21, 2010 | 02:26 AM
DeeGee's Avatar
DeeGee
Not an issue I've had on the Vette but the same switch has failed 3 times on my sons Camaro:
Its an easy fix. Just have the new switch to hand so you don't lose fluid as you swap it out.
Old Sep 21, 2010 | 03:54 AM
herZ06's Avatar
herZ06
Hmm, good info here... my reverse lights don't work either! Not sure it they flash when I set the alarm though, I'm going to have to check that out!
Old Sep 21, 2010 | 04:50 PM
myredht's Avatar
myredht
Thanks guys it looks like an easy fix.
Old Sep 26, 2010 | 02:54 PM
myredht's Avatar
myredht
My reverse lights work again thanks for the help, if you have a lift this is about a 3 minute fix and the part was $12.99 plus tax.
To Back up lights not working
