DIY LED lights
Old Sep 28, 2010 | 11:45 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Originally Posted by JTsangNJ
Stalion what LED strips are you using? They seem blinding but I like it
I found this set on ebay. They were pretty long then just cut them to length. The brightness in the photo is because of the camera flash...they should look like what tstar has in his vid and pics. I'll post up pics once I get them installed to compare.
Old Sep 29, 2010 | 12:01 AM
itzza427's Avatar
itzza427
COOL!! Just wondering,,,was it cheaper that buying them outright? I know job satisfaction also enters the equation too!!I admire the talent,,I'm not afraid of mechanical stuff,,,but lack electrical knowledge!! Nice job!!!
Old Sep 29, 2010 | 01:39 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
STALION: I"m curious what you used to re-seal the housing.
Old Sep 29, 2010 | 02:18 AM
00Corvette's Avatar
00Corvette
pretty sure he said clear silicone
Old Sep 29, 2010 | 05:04 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Hell I'm still in awe that he got the things apart!!!! I've tried!
Again, KUDOs Stalion!!!!!!!
Tim
Old Sep 29, 2010 | 07:14 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Perfect! Subscribing!
Thanks,Matt
Old Sep 29, 2010 | 02:43 PM
00Corvette's Avatar
00Corvette
Tim
remember, I don't think they're OEM lights so the adhesive is probably different from what GM uses also and could be more susceptible to "loosening" under extreme heat???
Old Sep 29, 2010 | 05:17 PM
tstar's Avatar
tstar
Good point...
Still good to know we can access Depos this way.
Tim
Old Sep 29, 2010 | 08:14 PM
STALION's Avatar
STALION
The glue used is fairly strong. Every time I gently pried with the flat head screwdriver you could hear cracks. This project could have potentially turned to crap if I left them in the oven for to long or cracked the lens trying to pry them off...If I cracked the housing, no biggie I could plastic weld it, but you can't fix a lens. (I did scratch one of the lens when taking them off)
Granted this was my first attempt, so if I every had to do another one I have a better feel for what to do vs what not to. I saved money by doing everything myself but it still does come with a price...one mistake and I would have paid over what JW is asking for a set that is already pre-fab, but I was willing to take that risk...I just like messing with things so for me it's more of game and I get enjoyment out of it!
Besides Tim, (tstar) inspired me (inside joke)
Good point...
Tim
I got some pics...I'll try and post them before the weekend.
Old Sep 29, 2010 | 08:40 PM
paint-tech's Avatar
paint-tech
I say great job!!! Its not for the timid though. Great writeup
Old Sep 30, 2010 | 02:22 PM
0ddball's Avatar
0ddball
Just throwing this out there, is it possible to get like multicolor LED and change the color if you want? Just throwing it out there..
Old Sep 30, 2010 | 05:50 PM
STALION's Avatar
STALION
Top people to ask would be Tstar, JWmotoring, and Radioflyer...
Old Sep 30, 2010 | 05:53 PM
  #33
tstar's Avatar
tstar
Swap me out with nascar57!
Tim
Old Sep 30, 2010 | 06:03 PM
  #34
TheRadioFlyer
Supporting Vendor
Is is possible? Yes.
Is it legal: probably not. (depending on colors)
Old Sep 30, 2010 | 06:38 PM
  #35
0ddball's Avatar
0ddball
Good point, didn't think about the legality of it. Thanks.
Old Sep 30, 2010 | 07:29 PM
  #36
stormrider's Avatar
stormrider
Tim has a bad habit of doing that
Nice work on the DIY LEDs
Old Oct 1, 2010 | 05:40 AM
  #37
tstar's Avatar
tstar
Yeah as I wait for the ACI Splitter Lip you're having made huh?
Tim
To DIY LED lights
Old Oct 1, 2010 | 08:58 AM
  #38
stormrider's Avatar
stormrider
Tim
In the body shop as I write. Should be ready for me to pickup on Tuesday
Old Oct 2, 2010 | 05:39 PM
  #39
STALION's Avatar
STALION
Ok I'm looking for alittle help from the big guns of LEDs. I have everything installed and everything seems to work. The LED strip works as do the LED corner bulbs, but the DRL LEDs (switch back type) continue to hyper flash. I've added an LED relay to stop it from doing that but it didn't quite help entirely. Without the realy the indicator wouldn't blink, but the DRL's were still in hyper flash switching back and forth from amber to white...when I added the relay, the indicators began to work at proper speed BUT the DRL's were still doing the hyper flash. I tried turning the bulb 180 degrees then the bulb didn't work at all. I need some help on this one, it's driving me nuts!!!
P.S.
LED relay 2 prong with ground wire. I connected the purple and pink to the leads and the ground to black (just in case this info is needed...thanks.)
Old Oct 2, 2010 | 06:25 PM
  #40
TheRadioFlyer
Supporting Vendor
P.S.
In my experience, some switchback bulbs cause the car to just get freaky. There's no logical explanation for why this happens. Lights that normally don't flash (like in the insturment cluster) will start spazzing. My suggestion is to either try a different style of switchback or go to traditional LED tower bulbs.
