DIY LED lights
Old Sep 28, 2010 | 11:03 AM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Default DIY LED lights
Hello everyone,
There were a couple of threads that CF members started on how to add LED lights to the front corner/bumper lights on the C5. As far as I can remember no one completed the task. One member however did mount the flat style LEDs on the outside...not exactly the best option. So over the summer I got my hands on some clear corner lights and had some LED's from another project so I thought I'd give it a go.
Those of you who are into sport bikes will know that one of the popular mods is to add angel eyes/halo eyes, and LED's to the front head lights. This is done by baking the lights in the oven...scarry proposition for sure, but it's done all the time, and is the only true proper way to install the LEDs. I've seen advise in the past by others to drill holes in the corners and try and slip in the LED's...let me tell all of you this will not work and if you try you will only damage the lights. I will show you how I did mine in the pics below...I did however miss on set of pics on where to drill the corner of the lights to thread the wires through.
New corner lights and LED strip I used.
As for baking, not all lights are created equal. The lights I used are from Depot. The glue is not at all like the factory lights and I was worried that this would pose a problem. The only problem I had was determing how long to leave the lights in the oven. After talking to some friends who have done it on their motorcycle lights I had a better idea on what to do. I pre heated the oven to 210F and left the lights in their for about 15 minutes. The glue was still strong, so back they went for another 3 minutes...nope, still longer, I left them in for another 5, and now they started becoming easier to take apart, but still had to use some force. Overall I would recommend leaving them in for 20min, check them, and longer if needed. You shouldn't have to use that much force to get the lense off. If you hear cracking, put them back in the oven.
Because of the style of LED I used I had to trim some of the material at the corners of the lights. (right side trimmed compared to left)
Getting the LEDs to stay in place was a bit of a chore. There is a seam in the lights that this type of LED fit in just right. I used clear silicone and a little crazy glue to help hold the LED's in place. I had to also physically hold the lights until the adhesive began to dry. Then I used the clear silicone to put the lens back on the housing. As I said earlier the only pic missing is drilling a small hole just big enough to pass the wires through at the corner of the lights.
This is how they look completed.
This is how the LED's look powered by a 9volt battery and no flash on the camera
With the no flash and lights off.
Now keep in mind I like doing DIY projects. Those of you thinking about attempting this may just want to get a set from JW that are already pre made and have the wiring harness already attached. JW's are a plug and play system. I will have to splice into my wires to hook mine up. I did save some money, but it wasn't about the money so keep that in mind if your going to attempt it yourself.
Cheers.
Old Sep 28, 2010 | 11:43 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
DIY=
Old Sep 28, 2010 | 12:27 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
nice write up
Old Sep 28, 2010 | 12:33 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Very nice! BTW-where did you get those clear corner lenses? Me likey!
Old Sep 28, 2010 | 12:55 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Cool. I've never heard of anyone taking those apart successfully. We cut slits and seal the leds in.
If anyone needs the strips we sell them without the mod!
JW Motorsports
Banned Scam/Spammer
I have a couple left
Old Sep 28, 2010 | 02:11 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I've tried on the factory ones to no avail... They laughed at the heat!
Good job!!!!!!!! I have the exact same light assemblies but from JW, get some installed pics and we can compare!
Old Sep 28, 2010 | 02:20 PM
STALION's Avatar
STALION
I got mine on ebay before I found out that JW was selling them. They sat in my garage for a year before I decided to do this.
Using aftermarket lights was a concern, and I won't lie I cringed everytime I pried on the seam and head a "crack." They could have easily broke because the glue isn't the same as what's used on OEM lights.
I thought about cutting slits but I just didn't want to take a chance with this type of LED...maybe the flat style but these just seemed to big.
Old Sep 28, 2010 | 02:22 PM
STALION's Avatar
STALION
Nice! If I get a chance to install them this weekend I'll take some shots...curious to see how mine will compare to these...maybe if they're good enough JW will hire me
Old Sep 28, 2010 | 02:23 PM
JW Motorsports
Banned Scam/Spammer
We cut slits with those same strips. It's not easy.
Old Sep 28, 2010 | 02:26 PM
STALION's Avatar
STALION
Are you guys using the "depot" brand lights? I thought about the slits but couldn't see how to make them stay once you got the LED's inside...It was a pretty tight fit even with the lense off.
Old Sep 28, 2010 | 02:32 PM
tstar's Avatar
tstar
Cool... I'll keep a look out in here for your pics. I have a video in Youtube also as I tied the strip into the turn signals, isolated from the DRLs with a Diode.
http://www.youtube.com/watch?v=HMZ9pRzEtvo
Tim
Old Sep 28, 2010 | 02:36 PM
JW Motorsports
Banned Scam/Spammer
Yes Depo lights are what we use
Old Sep 28, 2010 | 04:48 PM
JTsangNJ's Avatar
JTsangNJ
Stalion what LED strips are you using? They seem blinding but I like it
Old Sep 28, 2010 | 04:52 PM
JW Motorsports
Banned Scam/Spammer
We have them http://www.shop.jwmotoring.com/produ...1&categoryId=4
19 inch is what you want for this mod
Old Sep 28, 2010 | 06:17 PM
tail_lights's Avatar
tail_lights
Looks great Great write up!
Old Sep 28, 2010 | 07:51 PM
miltievette's Avatar
miltievette
are they now your DRL's . JW you'll be getting a call from me very soon
To DIY LED lights
Old Sep 28, 2010 | 08:05 PM
tstar's Avatar
tstar
Not precisely, although they can be wored that way, get with JW on the options available. Here's mine in Day and Night mode;
Day;
Night;
Boy, those were taken awhile ago! My car's changed alot since those were taken...
Tim
Old Sep 28, 2010 | 11:41 PM
corvettedaddy11's Avatar
corvettedaddy11
I love those!!
Old Sep 28, 2010 | 11:44 PM
0ddball's Avatar
0ddball
That is straight sexy. very nice!
