Hi
I have a 2000 C5 auto with 12,000 miles which ran perfectly until yesterday. The engine sputtered and ran 3-4mph full throttle and DIC said reduced engine power, service traction control/active handling system.
Any ideas?
Thanks, Mike
I had a similar experience with my Camaro (flame suit on). It turned out to be corrosion on the throttle body connector. I would take the connectors off of the throttle body and sensors and check / clean them. Also, you could go to the dealership and let them do the analysis (around $130) and that would let you know what was wrong.
