Lowes Flush mount tail lights
Old Oct 9, 2010 | 10:05 AM
Charles Cyrus's Avatar
Charles Cyrus
Default Lowes Flush mount tail lights
This is my flush mount tail lights using Vetteman Jacks Instructions. I Think I got the wrong weatherstripping, but it came out pretty good; even my wife likes it!
Old Oct 9, 2010 | 10:32 AM
corvettedaddy11's Avatar
corvettedaddy11
I need to flush mount mine what did u use!!
Old Oct 9, 2010 | 11:19 AM
blackmachdown's Avatar
blackmachdown
i'm not a fan of the flush mounted look, but if you like it then im happy for you
Old Oct 9, 2010 | 11:55 AM
Charles Cyrus
03-15-2010, 11:12 AM #7
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10
2003 Chevrolet Corvette
My Corvette Photos
Here's all you need to do the flush taillight mod:
Parts should be able to be purchased at a local Home Depot.
Parts needed:
• 8 each ½” x ½” round poly spacers with .194” hole.
• 6 each ¼” x ½” round poly spacers with .194” hole.
• 8 each #8 x 2” panhead sms screws.
• 1 package 5/16” x 3/8” auto/marine closed cell foam gasket with sticky on one side.
• Black Sharpie pen.
Step 1 – remove screws from tail lights and carefully let them hang out of the opening by the wire harness.
Step 2 – using the Sharpie, color the heads of the #8 screws black. Push the tip of the pen into the Philips slots to cover the screw with color completely.
Step 3 – Install the foam gasket material onto the taillight housings where the lens meets the black part of the housing, sticking the gasket to the black housing portion.
Step 4 – On the two inboard taillights, install the screws through the holes on the housings and slide 1 each ½” spacer and 1 each ¼” spacer over the screws and slide the taillights back into the openings and tighten the screws.
Step 5 – On the two outboard taillights, repeat step 4 except on the outer most taillight screw only install a ½” spacer and then tighten the screws.
The difference between this installation guide and others is that the others used 1” spacers. When the 1” spacers were used, the top of the taillights stuck out a little on the top and just didn’t look like a factory install.
Old Oct 9, 2010 | 02:56 PM
corvettedaddy11
On my way to lowes thanks!!
Old Oct 9, 2010 | 03:35 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
While you're there pick up some Hillman hinged screw covers...
Old Oct 9, 2010 | 03:44 PM
manley845's Avatar
manley845
Not sure how I like it yet...
Thanks for giving me an idea though. I just might try and see how it looks in person and on my car
Old Oct 9, 2010 | 03:58 PM
corvettedaddy11
That gives it a finished look thanks Tim!!
Old Oct 9, 2010 | 05:11 PM
Marine One's Avatar
Marine One
I also used VetteMan Jack's instructions but mine didn't come out quite as flush mounted as yours did. Mine are still slightly recessed. I think yours look great.
To Lowes Flush mount tail lights
