[Z06] 2002 Z06 Repair or Replace Engine
Old Oct 15, 2010 | 11:38 AM
Stanley Olkowski III's Avatar
1st Gear
Default 2002 Z06 Repair or Replace Engine
The fourth (4) broken valve spring resulted in the valve falling into the cylinder, damaging the head, the piston and the cylinder wall.
The vehicle has 85,300 on the odometer and is under warranty.
The dealer wants GM to replace the engine.
I am concerned about matching numbers.
My questions are:
Should I be concerned about matching numbers?
Should I ask for a replacement engine?
If GM will not replace the engine, should ALL of the rotating parts be replaced?
Thank you for any advice you can provide.
Stanley
Old Oct 15, 2010 | 01:16 PM
bumble-z's Avatar
bumble-z
Sorry to hear of youe 02 Z engine failure.
It's too late now to worry about matching numbers on your engine.(Best to get a replacement)
Your dealer & GM , have to take total responsibilty for not having ALL the springs, retainers, keepers & seals, changed all at the same time.
This is what happened when the dealer & GM decided to play Russian Roulette with your engine.
If they decide to replace motor with an engine with approximately the same amount of miles, your right back into the same sinking boat, in regards to old springs that need to be replaced.
Good luck.
Old Oct 15, 2010 | 01:25 PM
golfinz's Avatar
golfinz
If GM wont replace the entire motor (ie long block), which I don't think they will, then its the perfect time to build it to make more power!
Old Oct 15, 2010 | 01:51 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Ask for the old engine back anyway....
Matching numbers wont matter on these cars for another 30+ years.
Old Oct 15, 2010 | 01:58 PM
ZZ06's Avatar
ZZ06
They better replace the motor and not just said parts. That would be a half *** job the I personally wouldnt accept.
Old Oct 15, 2010 | 03:44 PM
Han Solo's Avatar
Han Solo
If it gouged the cylinder wall they they will probably out a LS6 crate engine in.
Serves em right too!
Old Oct 15, 2010 | 04:25 PM
Tech's Avatar
Tech
There are no numbers on your engine tied to your specific vehicle. Fight for a crate engine.
Old Oct 15, 2010 | 05:04 PM
GM Fan's Avatar
GM Fan
So they sat there changing out valve springs as they broke on more than one occurence, didn't just do the whole set when the first one broke? They deserve to eat the price of a new engine if that is the case...
Anyway, I'd insist on a new (not remanufactured) LS6 crate engine/long block. That is what mine was replaced with when the engine turned out to be bad not long after purchase, although it was a third party warranty from the Chevy dealer I purchased the car used from.
Old Oct 15, 2010 | 05:23 PM
AU N EGL's Avatar
AU N EGL
screw matching numbers. Hone that sucker out to a 396 and rebuild.
Old Oct 15, 2010 | 06:08 PM
81c3's Avatar
81c3
This isnt a 63 Z06, its a high production C5. Dont worry about matching numbers, its not gonna matter. Demand a brand new crate LS6 and dont leave until they commit to it in writing. PERIOD.
Old Oct 15, 2010 | 06:09 PM
Brian1997LS1's Avatar
Brian1997LS1
Engine numbers on these cars mean nothing in comparison to matching numbers on older vettes. ANd even then the only people that it matters to are the people that it matters to.
Ive personally alway been more interested in the quality fo the engine in a car. Not the number on it. A few are rare and worht more because of it but none of the vette engines being produced today will ever be rare while we are still alive.
Get a new engine if you can. Much smarter and better choce thatn patching up and older motor because it has soem numbers on it that in reality mean nothing.
Just my thoughts. Good luck to you what ever you decide. Or what ever GM decides for you i should say.
Old Oct 15, 2010 | 06:32 PM
zeevette's Avatar
zeevette
If the cylinder wall is damaged, (along with the other damage) you pretty much have no choice but to replace the longblock. Sure, you could sleeve your present motor, and then replace everything else, but the dealer isn't required to go that far. I wasn't aware that the blocks didn't have vehicle specific number stamping, not that our cars will ever become a collectable. The fact that our LS6s don't have to match works for me, because if I blow 'er up with the SC, I'll have to forge/shortblock anyway. Good luck with your dealer.
Old Oct 15, 2010 | 08:53 PM
arkus's Avatar
arkus
If you plan on keeping your car 20 years then yeah keep the original motor but if not , go with the newest and best engine you can .
Old Oct 16, 2010 | 11:43 PM
NatB's Avatar
NatB
It's a Chevy- not a Ferrari. Get a replacement crate engine and drive the hell out of it.
Old Oct 17, 2010 | 01:52 AM
LT1driver's Avatar
LT1driver
what makes you think there are no numbers linking motor to car???? there are casting numbers if not a serial number etched on block I believe. If I wasn't so lazy I would go out and look at a salvage block I have to be 100%. but if it were me I would go crate, less than 6k and if required pay difference and you even get 2yr/24k or something like that on engine or maybe more.
Old Oct 17, 2010 | 01:43 PM
AU N EGL's Avatar
AU N EGL
Even on the older cars that are rebuilt, there are plenty of guys who can GIVE you matching numbers, and no one will ever know the difference.
Old Oct 18, 2010 | 03:06 PM
2K3Z06's Avatar
2K3Z06
From: KADS- If it has wings or an engine, I can break it. Dallas TX
***** The 4th broken spring ***** Dude, replace the springs as a set(16). and stay off the rev limiter.
To 2002 Z06 Repair or Replace Engine
