I see you are from Glendale.. (I lived in Burbank back in the 70's). Is "Deeds Automotive" still on Magnolia Blvd? The owner, Glenn Deeds is a old Bonneville racer and was always pretty good with my Vette back then. I would assume he would be up to date on the c-5's if you run into trouble.. Just a suggestion,
Good luck!
Sounds high to me Bill Curlee suggests it should be 20mA dormant
One of the common problems is the switch on the seat motors, particularly the lumbar switch. Might be worth starting there. The other common mistake is to leave the interior lights turned on at the rotary switch on the instrument panel.
I'd assume 20mA was the normal draw for our rides on "sleep mode" (car shut off with no lights running for over half hour)
looks like I have to perform the "pull and check" for the relays
Here is a copy from a Bill Curlee post a ways back followed by the procedure to check for and isolate a current draw:
The correct BCM current draw should be 20 Milliamps or less. Most C5 run around 25ma but I have see some as low as 15 ma.
Leave the engine compartment fuse box for last and start with the passengers compartment box first. Pull the power seat breakers FIRST! The power seats have a tendancy stay on and cause this issue.
Also pull the fuses for the Bose system amp.
Examine the car in the dark for lights staying ON.
Once you prove the interior circuits good,,, check the headlight circuits, and then test the current draw of the alternator.
Look at my electrical stickey. I think I cover this in detail in that post.
There are several COMMON things that cause excessive current draw
-Seat multifunction switch & Lumbar Switch
- Bose Amp relay stuck on
- Alternator didoes bad and drawing current
- Headlight control module bad
- Interior light on (check in the dark)
- Added aftermarket accessory not shutting off
Have you checked the battery? If not, have a reputable auto repair shop perform a load test and also have them check the alternator output. If you have the original AC Delco battery, it could be on its last legs.
Even a 400mA drain should not cause a fully charged battery that's in good condition to not be able to start the car if it just sat overnight.
hmm....mechanic shop tested: said its holding charge and works fine,,,not original battery,,,
but there's a little sticker on it that says 7/09...could that be expiration date?
After reading this post I decided to check my draw on my battery as I had a problem over the winter. I hook up the meter as in the picture on the 10 amp setting and got a reading
of 2.42 is that reading times 10 because of the 10 amp setting or is it actually 2.42 amps
and is it a good reading
