Vert Trunk lid question?
Old Dec 1, 2010 | 11:22 PM
dmarkshark's Avatar
dmarkshark
Default Vert Trunk lid question?
This will be a fast one. I replaced the struts on my front lid (for the top), and it magically opened by itself when I pushed the button, that was really cool. Will the trunk lid do the same with good struts?
Old Dec 1, 2010 | 11:35 PM
MarkyMarkGTM's Avatar
MarkyMarkGTM
doubties
Old Dec 2, 2010 | 09:46 AM
Phanni's Avatar
Phanni
Someone sells a spring for the trunk for something like $10.00 that doesthe job really well
Ithink it's calledthe 'trunk popper' or sometrhing like that.
Old Dec 2, 2010 | 09:47 AM
dougbfresh's Avatar
dougbfresh
The truck will just pop up abut 3" when everything is correct.
Old Dec 2, 2010 | 09:48 AM
Phanni's Avatar
Phanni
http://www.c5trunkpopper.com/
Old Dec 2, 2010 | 10:07 AM
dougbfresh's Avatar
dougbfresh
Originally Posted by Phanni
A couple drops of oil make the rear hatch work NICE. Cost's less than a penny.
Old Dec 2, 2010 | 10:15 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Where are the oil points? On the struts?
Old Dec 2, 2010 | 10:29 AM
dmarkshark's Avatar
dmarkshark
I guess what I was reallly asking was should the trunk lid open up all the way with struts working properly? Like the front lid does? The reason I was curious was because my front lid did not lift up, I put new struts on it and now it raises up without my lifting on it, and was just curious if the trunk lid should also do this as well? Not having been around Corvettes that much, let alone Verts, I have really never seen this to know one way or another.
Old Dec 2, 2010 | 10:31 AM
dougbfresh's Avatar
dougbfresh
On the strut rods and hinges. Made mine work like brand NEW.
Old Dec 2, 2010 | 10:33 AM
dougbfresh's Avatar
dougbfresh
NO, the rear trunk lid only pops up about 3" when working right. I would not want any of the lids to come up all the way, especially the tonneau cover. If the wind catches any of these it could be UGLY.
Old Dec 2, 2010 | 10:47 AM
MSG C5's Avatar
MSG C5
Thanks. Just a little WD40 or is there something better to use?
Old Dec 2, 2010 | 10:51 AM
MSG C5's Avatar
MSG C5
Wow. I don't know if I would want my front hood to pop up all the way after releasing the hatch in the cockpit. I like that it only pops up an inch or so and that I then lift and extend it up.
I also have a vert and I think oil/lubricant is the best solution as the trunk is also only supposed to pop up an inch. I guess new, stronger and more compressed struts could be the solution. Who manufactured your replacement hood struts?
Old Dec 2, 2010 | 10:52 AM
BATM4N's Avatar
BATM4N
Old Dec 2, 2010 | 11:10 AM
dougbfresh's Avatar
dougbfresh
I just used motor oil.
Old Dec 2, 2010 | 12:28 PM
Kevin Kuse's Avatar
Kevin Kuse
Where did you get the struts and do you have part #'s!
I have been looking for them because my lid just falls shut!
Old Dec 2, 2010 | 01:08 PM
DeeGee's Avatar
DeeGee
The lid falling shut is a different problem to it not popping up
You need a new strut
Document ID# 656600
2002 Chevrolet Corvette
________________________________________
Folding Top Stowage Compartment Lid Struts Replace
Removal Procedure
1. Open the folding top stowage compartment.
2. Remove the forward end of the strut from the hinge ball stud.
3. Close the folding top stowage compartment lid.
4. Open the rear stowage compartment lid.
5. Remove the strut from the rear ball stud.
Installation Procedure
1. Open the rear stowage compartment lid.
2. Position the rod end of the strut through the access hole between the quarter panel and the support.
3. Install the strut to the rear ball stud.
4. Close the rear stowage compartment.
5. Open the folding top stowage compartment.
6. Install the rod end of the strut to the front of the hinge.
7. Close the folding top stowage compartment.
Document ID# 656600
Old Dec 2, 2010 | 01:20 PM
dmarkshark's Avatar
dmarkshark
Kevin, I do not remember where I got the front deck shocks, I just did a search to find them. If you can't find them PM me and I will look it up fo you. Same as the factory ones.
Pretty easy to put on, as long as you go the right direction when putting them on. Back first, then the front.
To Vert Trunk lid question?
