stall converter help???
Old Jan 17, 2011 | 07:34 PM
timritchieblue's Avatar
timritchieblue
Default stall converter help???
k, found a set of gears, 3:42. pretty much setteled on a RPM stage 5 trans, if i can get my car their? (no 2nd gear) what converter to go with? how much stall? what is torque multiplication rate? only got 4k, gear cost me $500
yank?
Old Jan 17, 2011 | 07:39 PM
robert miller's Avatar
robert miller
yank?
Not enough info here. Believe me talk to the guys there. Tell them what you want are what you will end up with after you are done. Then they will put the correct converter in the car for you. They did me on my car....
Old Jan 17, 2011 | 07:48 PM
Gitusum's Avatar
Gitusum
yank 3200 for street use is a good converter and its what i am using
Old Jan 17, 2011 | 09:28 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
Exactly what I'm using. RPM 3:42 gears, RPM Level IV - A4 and a Yank SS3200.
Old Jan 17, 2011 | 09:37 PM
futuretech's Avatar
futuretech
I have an A4 with 3.42 gears and a Yank SS3600. I take it to the track a lot (250 passes a year) and really like it. Hard to remember what a stock converter was like.
Call Yank and tell them this info
HP (rear wheels)
gear ratio
intentions for car
They will give you good advice.
Old Jan 18, 2011 | 12:50 AM
Bluefire's Avatar
Bluefire
My A4 has 3:42's, stock trans, and a Yank 2800 stall. Converter looseness is barely noticeable and produces a hell of a kick. My $0.02
Old Jan 18, 2011 | 09:41 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
I'm pitting in 3.42 and a Yank SS3200, Can't wait to feel the difference, I hear this is a very nice setup for street, and some track time!
Old Jan 18, 2011 | 11:43 AM
timritchieblue
X2, cant wait,,,,, bring on the mustangs
Old Jan 18, 2011 | 11:57 AM
dankhts's Avatar
dankhts
S/A mine... seems to stall at about 3000 though... maybe because of my mods....
Old Jan 18, 2011 | 01:14 PM
Bluefire's Avatar
Bluefire
What mods do the think may cause that? Could that possibly be addressed in the trans tune? Shift/downshift point tuning may help.
Cheers
Old Jan 18, 2011 | 02:35 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
YANK 2800 - 3200
I am running the ss3200 stall and couldn't be happier with it (A4, 3.42, Yank 3200). The street behavior is astounding, minimal parking lot slip very easy to drive. It is a tight converter and works well on the street and drags
Talk with Dave @ YANK and he'll set you up
Thanks,Matt
Old Jan 18, 2011 | 04:12 PM
dankhts's Avatar
dankhts
Cheers
mostly the cam..... and compression ratio I'm told by my tuner.... good tune though.... I have no problem with how it's set up or what it stalls at, hits hard and lots of fun too
Old Jan 18, 2011 | 04:39 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Talk to Dave at Yank he will help you. I run a blower with a Yank
SS2800 and it works great!!
Old Jan 21, 2011 | 10:07 PM
timritchieblue
well i have been talkin with jeremy @ RPM, they sell PI stalls? been looking at them now. he said i should go with the 2800 vig. im thinkin i what more stall if im going to spend the money, like a 3200? anyone using the PI 2800. getting it all installed feb 12th
Old Jan 21, 2011 | 10:29 PM
C5XTASY's Avatar
C5XTASY
Vigilante stalls usually actually stall higher than what they're rated at. I would suspect that the 2800 Vigilante will actually stall at about 3000-3100, or so. I have no idea why they rate them as they do. I would recommend a Yank. They stall where they're rated at and are extremely tight. They are a great piece of machinery, IMHO.
Ed
Old Jan 21, 2011 | 10:50 PM
timritchieblue
thanks, i was stuck on getting the YANK, but after talking with Jeremy @ RPM, he said they have seen lots of problems (clutch material) with them. i know he sells the PI converters, but im getting a RPM trans installed at the same time. i don't want any....."well the converter you bought was sh*t, and we got to pull it apart again... so im stuck with a PI converter. i think their both good products. just wanting to get my moneys worth,
Old Jan 22, 2011 | 08:06 AM
VET IT B's Avatar
VET IT B
What does PI stand for?
To stall converter help???
Old Jan 22, 2011 | 08:33 AM
Gitusum's Avatar
Gitusum
another vote for yank ss3200
Old Jan 22, 2011 | 11:01 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
This is first time that I have heard anything negative about Yank!!!!! I wonder if it's because RPM sells PI's? things to make you go hmmmmm!!
And no you are not stuck with there stall, They just don't want to install someones stall that is not theres, Look up past threads about Yanks and count the negetive remarks! Make sure you do your homework before you buy!
Old Jan 22, 2011 | 11:04 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Precision Industries, they make Vigilante Converters
