Looking for more cornering stability.
base spring.
I feel like maybe it's the spring causing me headaches.
When the car is in transitions, or toward the edge of its handling it will get, for a lack of better words, wobbly.
Is this just a function of having too much shock for my springs?
How much will springs hurt my ride quality?
C6 z06 shocks. I think the swaybars are C5 z06.
If I can get my C5 to handle a well as my Saab wagon (which has aftermarket swaybars and springs, stock struts) I will be more than happy.
If It will handle as well as my old c4 z51 did stock, I would be ecstatic.
The car has always kind of had a "buick" feeling when I really push it.
If it rides like a buick, you probably have too much spring and not enough dampening. When you say wobbly, I'm interpreting it as bouncing around after a turn. If you have upgraded your sway bars, you must remember that they act like springs in a sense. If you twist them, they have to rebound too. If your "shocks" aren't up to the task of dampening that rebound, along with the oscillation of your springs after turning, then you'll experience that "buick" boat like wobble.
If you go with too much dampening, then it will be overdamped and ride harsh. You won't have any cushion from your springs.
EDIT:
I initially thought you were referring to transition out of a turn. If thats not the case, you can probably disregard the above. I'll just leave it for added info.
I think you are talking about in a turn, the car feels unstabble? Can you describe the feeling more? is it "twitchy?"
- alignment ( need the aggressive Z06 alignment or better. stock alignment will not do at all ) the more negative camber the better the cornering.
-tire age( not miles ) has more to do with handling. it tires are more then 2 years or 1500 miles your cornering ability has been comprised. New tires always corner best. this is the hard part as ppl can not buy new tires each year. so the compromise
- If the car is lowered more then 1" your corning will be highly reduced.
- Then sway bars
- then shocks
if the car feels unstable in corners sounds like it may be:
- under-steering. If that is the case, the tire widths need to be closer in the same size.
- alignment is OFF
- one shock is shot.
- end link came unbolted
32 PSI COLD is too high. 30 psi HOT ie 25 psi cold for better performance for most tires.
Myself I do not like soft springs, to much dive & squat not that this is your issue.
As mentioned above aggressive alignments are more fun! With softer springs you will have more body roll so even more negative camber is needed. Another reason I like stiffer springs.
I had never thought of the over damped situation, that makes allot of sense! That would really aggrevate side steeping.
one of my vettes is a track or road course car only
alignment:
front
camber -2.5*
toe: 1/32" OUT
Caster: Max but equal
Rear
Camber -1.25* 1/2 of front
toe: 1/32 IN
no ranges, no cross. EXACT.
Suspension:
GM T1. Just had shocks revalved.
Lowered 1" from stock or all the way UP for the T1
Tires Hoosier R80s
Front:
18x12 with 18x305/30 cold 20 PSI HOT 27 psi
Rear
18x13 with 18x335/30 Cold 18 PSI Hot 27 psi
can corner faster then most cars can go straight
two particular long sweeping corners a STOCK C5Z06 does about 45-50 before tires slide out. I do 75-80 mph might be able to push 82-83 mph before rear tires slide more then controlable.
So is it just a terrible pairing between the base springs and c6 z06 shocks?
The rebound is to slow as it is meant for a much stiffer spring. What happens is when the first bump is absorb & the spring is compressed. It cannot return quick enough so when you hit the next bump the spring is not ready or has not returned to the correct position. Then stacking occurs & the pogo stick effect begins.
I hope I've described this correctly if not maybe some of the suspension guru's will correct me.
alignment:
front
camber -2.5*
toe: 1/32" OUT
Rear
toe: 1/32 IN
Suspension:
Tires Hoosier R80s
Front:
Rear
Ride quality is a pretty big concern of mine. I'm getting picky in my old age.
I miss the handling of my 86 corvette, but NOT the ride.
When you're riding in a straight line, do you feel like you're in a buick with the car hitting a bump and you still feel the car oscillating ten miles down the road? Or do you feel the bumps in a short, abrupt, and harsh way?
Also, did you say the tires you're running right now are crap?
