Speed bumps?
Old Jan 24, 2011 | 12:40 PM
cnero's Avatar
cnero
Cruising
Default Speed bumps?
First time owner here. What is the secret to driving over speed humps/bumps and getting up the driveway without tearing off the air dam? Man this thing sits low! I understand from the owners manual that the air dam is hinged and scrapping is normal but sheesh, I just hate the sound.
Old Jan 24, 2011 | 12:43 PM
jrose7004's Avatar
jrose7004
Take everything at an angle. And take them slow.
Old Jan 24, 2011 | 12:46 PM
chrisk92's Avatar
chrisk92
Suspended by request 16 May 2012
Old Jan 24, 2011 | 12:50 PM
UM Rebel's Avatar
UM Rebel
Don't worry too much about the air dam,it will give. But do be careful of the rocker panels. They don't give and are expensive to repair.
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
The front airdamm is spring loaded and is designed to flex, the sound seems bad but you are not hurting anything. When going over curbs and speed bumps, approach them at a 45 degree angle, this will help with little scrape. If you want you can cut the airdamm a little bit. My car is lowered and I cut off 2 inches on mine. I have no problem with overheating issues and it does not scrape on curbs that much. Hope this helps you out!
Old Jan 24, 2011 | 12:59 PM
cnero's Avatar
cnero
Cruising
Default Thank you all!
This is wonderful having experienced people out there o ask questions of.
Old Jan 24, 2011 | 01:22 PM
DeeGee's Avatar
DeeGee
I had to negotiate some serious speed bumps at Nellis AFB. Always at an angle The air dam sounds bad when it scrapes but it's designed to take some stick. I have one road here in England that is straight but has some serious "undulations". I ground out at about 70 every time and it sounds like I've taken the air dam off the car. It seems to survive.
Old Jan 24, 2011 | 01:29 PM
KenShores's Avatar
KenShores
Welcome to corvette ownership. It's a great fit for neurotic car owners. Just wait until you come up a little too far head on to a curb when you park. Not only does the air dam make noise, you get a ride on you frame a bit too. But not to worry too much, there are many things you can buy for your vette.
Old Jan 24, 2011 | 01:34 PM
And even it it drags on the front air dams, they are easy and relatively easy to replace when they get really scraped up.
Old Jan 24, 2011 | 01:48 PM
darkstar.c5's Avatar
darkstar.c5
ive seen the set of 3 (if you look you will see that its spring loaded) for about $100... so no worries... thats the cheapest thing on our cars
that being said.. SLLLOOOOOOW is the key.
Old Jan 24, 2011 | 01:59 PM
Rockbridge's Avatar
Rockbridge
St. Jude Donor '11
Just like most things in life; there's nothing that can't be fixed if you throw enough money at it!
Old Jan 24, 2011 | 02:12 PM
76 VETTE's Avatar
76 VETTE
Old Jan 25, 2011 | 09:18 PM
jdot's Avatar
jdot
My driveway has a bit of a steep entry angle and I always scrape when coming and going and the sound drives me nuts but I won't stop driving my vette because of it. Like the guys said; slow, angle, easy does it. Enjoy your car.
Old Jan 25, 2011 | 10:14 PM
Carcass's Avatar
Carcass
Mine always scrapes in and out of my driveway,angle or not,and it hasn't hurt it a bit in over 2 years of daily driving-that's what they're made for.
The front frame rails handle parking curbs real well,too,since, even after all this time,I still seem to think the front end of the Vette is about 6 inches shorter than it actually is...
"Fangs" from SacCity Vettes made that a bit less of a problem lately,though.
I don't do it all the time,but it still happens way more often than it should...
Old Jan 25, 2011 | 10:23 PM
Qwik01's Avatar
Qwik01
Anlges will save your life. I have 3.5" of ground clearance and I take everything at a 180 degree pretty much.
Old Jan 25, 2011 | 11:16 PM
Triton4C's Avatar
Triton4C
Lol you go at everything backwards?
Old Jan 25, 2011 | 11:50 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
The airdam is plastic and it bends backwards (it's like a stiff flap), I'm more worried about the parking blocks that you can't see when you pull into a parking spot.
To Speed bumps?
Old Jan 26, 2011 | 12:12 AM
Qwik01's Avatar
Qwik01
Aw man. I meant 90 degree angles.
Old Jan 26, 2011 | 10:49 PM
jdot's Avatar
jdot
Yeah I hate those blasted parking blocks too.
Old Jan 26, 2011 | 11:13 PM
HowlinC5's Avatar
HowlinC5
angle it and don't pull close to curbs.
