Vortex Lip Install (Pics)
Old Mar 22, 2011 | 06:54 PM
  #101
vetten76's Avatar
vetten76
Originally Posted by vetten76
I have the rear spoiler, just have no idea how to post them!
Got my lip today. It's worth the money just to see how hard they work at packing it for shipment. Very nice piece. This should be fun to mount. Of course I now have a pictorial of how to do it!
Old Mar 22, 2011 | 11:51 PM
  #102
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
Post some pics....this should help. Click here!
Old Mar 23, 2011 | 12:20 AM
  #103
vetten76's Avatar
vetten76
Fine. I'll do this tomorrow. I really like my rear spoiler. It's just right.....
Old Mar 23, 2011 | 07:05 PM
  #104
vetten76's Avatar
vetten76
Here goes nutten.......
Old Mar 24, 2011 | 05:48 PM
  #105
GreensKeeperNJ's Avatar
GreensKeeperNJ
That rear soiler looks great, have to put it on my list.
Old Mar 24, 2011 | 08:19 PM
  #106
vetten76's Avatar
vetten76
I really like it. The front lip will tie in my black center Cray wheels, tinted windows and rear spoiler on my spiral gray car. The rear spoiler was a little tough to mount perfectly. I ended up using 3M double sided tape, lining it up with several "guides" I taped to the car to get in on straight and finished it by using 4 screws through the tail light openings up through the under section into the bottom of the spoiler. After I'm done mounting the lip, I'll take a full car picture, now that I know how to post pictures. No one in my circle of Vettes here in San Diego have this rear spoiler so it makes mine a little different than all the others.
Old Mar 25, 2011 | 08:39 PM
  #107
vetten76's Avatar
vetten76
Here is my finished carbon fiber lip. Easy to install. I did mine by myself by masking taping in place then using a driver to drill through the mounting screws through the fiberglass without pre drilling. Way easier. I used s/s screws around the inside to attach to the bumper itself. No double sided tape. I used bumper washers where I could and I used a hand grinder to cut away the material for the center wind deflector. Now the question is, can I actually learn not to hit anything when I park? This completes the outside of my Vette.
Old Apr 26, 2011 | 05:37 PM
  #108
Eber's Avatar
Eber
i just got my shipment of side skirts, vortex front lip and Spl rear spoiler all in carbon fiber today!!!!!!!! I will try to get it all done this weekend and have pics up later in the week..I am stoked.. I have a 2000 black FRC.
Old Apr 26, 2011 | 07:33 PM
  #109
doublec4's Avatar
doublec4
You definitely owe us pictures when you get that stuff installed! Sounds like a nice combination!
Old Jun 17, 2011 | 02:59 PM
  #110
tslick98's Avatar
tslick98
Finally got mine on. The install was pretty easy. I did mine with no help. Thanks Pete
Old Jun 17, 2011 | 06:27 PM
  #111
vetten76's Avatar
vetten76
Really nice C5. Your lip looks outstanding. I keep dragging mine and actually put a slight crack on one side. Easy to fix and hide. Nice job!
Old Jun 17, 2011 | 07:39 PM
  #112
Eber's Avatar
Eber
is anyone else having overheating issues with this lip. I put miine on today and its now running at 110 degress. dont know what the conversion is but it went up at least 10 degrees by adding this lip
Old Jun 17, 2011 | 07:40 PM
  #113
Eber's Avatar
Eber
oh..and il will try to upload pics tom. car is covered in dust from teh body shop. Had everything moulded to the car to make sure its flush
Old Jun 17, 2011 | 07:44 PM
  #114
tslick98's Avatar
tslick98
No temp change here.
Old Jun 17, 2011 | 07:50 PM
  #115
02z06dave's Avatar
02z06dave
Originally Posted by MSG C5
The manufacturer needs to fix this and perhaps add the pre-drilled holes/hardware. Even if they have to increase the production cost to do so and raise the retail cost $50 to cover the expense. This should be bolt on/plug & play.
Very nice write up and pics. Thanks!
I'm a little concerned with how far back the spoiler goes back as it seems to cover a lot of the original open air flow box. It seems as though by looking at the pictures, there is only about 1" between the back lip of the splitter and the OEM flex spoiler which is designed to push air up into the intake. Or does the front opening in the splitter supposed to direct the air up instead?
In the end, it looks great!
BTW - you might want to get a set of Fangs.
id rather save the money and spend a few minutes fitting it. it doesnt take long and the money saved is well worth it.
Old Jun 17, 2011 | 09:55 PM
  #116
Eber's Avatar
Eber
i have big heat issues now and i guess will have to cut the front lip back to allow for more air
Old Jun 17, 2011 | 10:08 PM
  #117
Quik Z06's Avatar
0Quik Z06
Former Vendor
Did you install the lower air dam (the center one?) I don't see why temp's would change, since you have that opening in the front that would allow air in.
To Vortex Lip Install (Pics)
Old Jun 17, 2011 | 10:11 PM
  #118
Eber's Avatar
Eber
the air dam is still on and i think that may be the problem. maybe if i remove all the stock undercarriage parts that might work
Old Jun 17, 2011 | 10:15 PM
  #119
Quik Z06's Avatar
0Quik Z06
Former Vendor
I wouldn't think so especially if others are not experiencing higher temps. It would be simple to cut some off if the area from the lip to air dam is close, but I don't know, thats weird.
Old Jun 17, 2011 | 10:21 PM
  #120
Eber's Avatar
Eber
for those that arent experiencing heat issues did you keep the stock air dam IE) spring loaded center piece on or off?
