tapping noise from engine
Old Feb 2, 2011 | 11:03 PM
swollix's Avatar
swollix
Default tapping noise from engine
Ugh please tell me I don't have a bad lifter... The noise is always there, and it keeps in pace with engine RPM. I tried to take a video, but the camera mic is terrible...
Old Feb 2, 2011 | 11:17 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
What year is your vette? it could be piston slap also.
Old Feb 2, 2011 | 11:22 PM
swollix's Avatar
swollix
2002. It does this all day regardless of how long it's been running or engine temps or anything.
Old Feb 3, 2011 | 03:13 PM
Z06 Nate's Avatar
Z06 Nate
If it sounds like a tick, could be a small exhaust leak.
Old Feb 3, 2011 | 03:16 PM
cor28vettes's Avatar
cor28vettes
run this by TECH
Old Feb 3, 2011 | 03:51 PM
draggon007's Avatar
draggon007
i had that same noise and it was a lifter.i waited to long to check it out and it broke and went through my engine like a ping pong ball.fix it before that happens
Old Feb 3, 2011 | 04:25 PM
killain's Avatar
killain
Oldtimer
Default Odd noise
I've heard a lot of LSX motors and they all had piston slap, which goes away after the engine is warmed up to like 175 degrees. But your sounds are more of a tapping noise, but that could be something in the sepentine belt routing, but I doubt that as well. So it could very well be lifter, but does it every go away ? If not I'd say it's something internal. But that's just my opinion. You did a great job of catching the sound. When I start my 2003 after sitting for five months, I get a lot of strange sounds from the injectors to the very often Piston slap, I leave it run for 15 minutes and almost all the noises are gone.
Old Feb 3, 2011 | 04:43 PM
99 vett babycar's Avatar
99 vett babycar
get your lifters checked - now.
SUPERCRUZ's Avatar
SUPERCRUZ
Agree - Run this in the tech section. Certainly could be a lifer. You would be wise to go ahead and pull the valve covers off and check your rockers and valve springs. You might find your noise is coming from a broken rocker or valve spring. Good luck with it.
Old Feb 3, 2011 | 05:40 PM
Dave68's Avatar
Dave68
What viscosity oil are you running? I hope it's not 20W-50 or something similar.
Old Feb 3, 2011 | 11:50 PM
swollix's Avatar
swollix
The sound never goes away. The car is misfiring and throwing code P0300 now. I am using Mobil One 5w30.
Old Feb 4, 2011 | 02:27 AM
nolo263's Avatar
nolo263
From what I have read here probably a Valve Spring! Dont use the car, get it looked at NOW!
Old Feb 4, 2011 | 05:40 AM
wascapsfan's Avatar
wascapsfan
Throw a can of "Top Engine Cleaner" from GM in the oil first and see if that shuts the lifter up. It's a valve job in a can. I used it all the time when I was a Chevy tech and it was a miracle worker. If you have a stuck lifter, it will free it up. You didn't state the mileage.....Piston slap is possible but not probable. Lifter replacement is a decent sized job but not too bad. Pistons on the other hand usually signals complete overhaul.
Old Feb 4, 2011 | 11:33 AM
GeneT's Avatar
GeneT
My 2002 has 31,000 miles. when I start it, I get a tick, tick tick, but once it warms up, it goes away, and doesn't come back until the engine is cold again. I'm assuming it's a lifter as well, but, would it have to be replaced if it pumps up after warmup ??
To tapping noise from engine
