Lowering Question
Old 02-13-2011, 05:56 PM
ourblk96
ourblk96's Avatar
Default Lowering Question
I'm thinking about lowering the rear only; will this do any harm to the suspension or throw off the handling?
Old 02-13-2011, 06:06 PM
HowlinC5
HowlinC5's Avatar
If the rear sits lower than the front the active handling system won't be happy.
Old 02-13-2011, 06:13 PM
Gitusum
Gitusum's Avatar
you definately want to lower the front and rear not only will it ride funny but also look funny
Old 02-13-2011, 07:46 PM
ourblk96
ourblk96's Avatar
Okay I should have explained it better....I want to lower the rear so it's level with the front...so I don't have that 70's-80's jacked up rearend look that I have now..... does this make sense?
Old 02-13-2011, 07:58 PM
yaknow
yaknow's Avatar
You want to maintain some rake, or you will have active handling issues.
Old 02-13-2011, 07:59 PM
fastvett
fastvett's Avatar
Old 02-14-2011, 01:27 AM
striper
striper's Avatar
Aerodynamically and handling wise, the front end is supposed to be approximately 3/8" to 1/2" lower. If level it can generate lift at higher speeds.
Old 02-14-2011, 04:32 AM
4SFED Z
4SFED Z's Avatar
Wrong. Active handling would not be an issue. On the other hand, lift at high speeds would....
To Lowering Question
Quick Reply: Lowering Question
