[Z06] Brakes
Old Feb 17, 2011 | 01:28 PM
G.Rossman's Avatar
G.Rossman
St. Jude Donor '13, '15, ‘18, '21
Default Brakes
Since I plan to race this year and the Z I picked up need brakes I started calling around to get prices on parts. It looks like Napa can get me pads and rotors, front and rear, for around $360. This is the cheaper stuff they sell and I was curious if anyone else has used this? I figured they might not last too long depending on how much I get to race so no point is buying top end stuff to go burn them up right away.
Old Feb 17, 2011 | 01:45 PM
2K3Z06's Avatar
2K3Z06
From: KADS- If it has wings or an engine, I can break it. Dallas TX
I use the NAPA rotors with hawk pads. Just check the lateral run out of the rotors. the last time i did a brake job, one of the rotors was warped.
Not to bad, I have bought 16 rotors from napa over the years, only 1 was bad.
cheers
Old Feb 17, 2011 | 03:51 PM
G.Rossman's Avatar
G.Rossman
cheers
Sounds good, might stopp by today and them ordered in just in case we get some more warm weather soon.
Old Feb 18, 2011 | 07:54 PM
ZR1Orrico's Avatar
ZR1Orrico
5th Gear
I've been using the Napa rotors too, but the ones I bought were made in Canada, I heard that they are made in China now.
The rotors last quiet a long time on the track if:
1. Inststall the Doug Rippe brake ducts and spindle brackets to get air right on the rotor.
2. Use a good race pad, I've been using Porterfield R-4 pads and they really last and are more rotor friendly than Hawks.
Old Feb 19, 2011 | 01:08 PM
dbaker's Avatar
dbaker
TPS motorsports has the slotted rotors for approx $240.They are centric blanks and they cut the slots.
I like mine with the HPS pads & Goodridge SS lines.
\db2
carolina
Old Feb 27, 2011 | 12:06 PM
TPSMak's Avatar
TPSMak
Supporting Vendor
St. Jude Donor '11
My suggestion for brake rotors are slotted as they will give you the most braking surface and not be prown to cracking.
If you REALLY like the cross drilled look we have a dimpled slotted solution which doesn't crack but looks just like a cross drilled rotor. Also, ALL our rotors are zinc coated to prevent rusting.
If your looking for a performance upgrade I would recommend our Stage 2 Brake Upgrade package which includes.. Motul Brake Fluid, Stainless Steel Lines, Hawk HPS Brake Pads, and the rotor of your choice for only $529. If you just want rotors and pads we can do the whole set for $329.99 delivered to your door... CHEAP THAN NAPA!
http://www.tpsmotorsports.com/catalo...?q=tps+stage+2
__________________
TPSMotorsports.com
Mike Mak
2705 Lafayette Street
Santa Clara, CA 95050
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
Authorized dealer of Corbeau Seats, ECS Superchargers, Edelbrock SuperChargers, A&A Superchargers, Kooks, Whipple, Magnalow, Corsa, Borla. LG Motorsports, Procharger, Billy Boat Exhaust, AWE Exhaust, American Racing, TPS Brake Rotors/ Kits, Stainless Steel Brake Lines & much more...
Old Feb 27, 2011 | 12:15 PM
gmccreary's Avatar
gmccreary
I run stock rotors with Carbotech XP-10s in the front and Xp-8s in the rear at the track. For me, rotors are a consumable item just like brake pads. I cracked 3 front rotors at Road Atlanta last December so I just buy the stock ones from whomever has the best price. I will probably update my front brake cooling to either the DRM or Quantum Motorsports kit soon.
Old Feb 27, 2011 | 04:36 PM
Last C5's Avatar
Last C5
Slotted, dimpled, cross drilled, cryogenic, and blessed by the Pope rotors won't last significantly longer on the track than the cheapy NAPA's.
Like McReary said, they're a consumable. I ran the Carbotech 10/8 set up for several years and now I've switched to their 10/10 set up with two piece rotors.
Old Feb 27, 2011 | 05:27 PM
AU N EGL's Avatar
AU N EGL
NAPA rotors and Wilwood H or PFC-01s brake pads, Castrol SRF brake fluid.
Old Feb 27, 2011 | 08:53 PM
G.Rossman's Avatar
G.Rossman
$330 for front and rear rotos and pads? Is that shipped?
Old Feb 27, 2011 | 09:15 PM
TPSMak's Avatar
TPSMak
Supporting Vendor
St. Jude Donor '11
TPS Rotors of your choice with Ceramic Pads for $330 shipped to your door
Old Feb 27, 2011 | 10:45 PM
MTPZ06's Avatar
MTPZ06
So...slotted rotors, and what brand of ceramic pads??
Old Feb 27, 2011 | 10:49 PM
TPSMak's Avatar
TPSMak
Supporting Vendor
St. Jude Donor '11
The pads are made by Centric who is the owner of Stoptech
Old Feb 27, 2011 | 10:53 PM
MTPZ06's Avatar
MTPZ06
Posi-quiets?
Old Feb 27, 2011 | 11:28 PM
TPSMak's Avatar
TPSMak
Supporting Vendor
St. Jude Donor '11
Posi-quiets?
Yup... Posi-Quites
Old Feb 28, 2011 | 08:57 PM
G.Rossman's Avatar
G.Rossman
Yup... Posi-Quites
Sounds good to me...
Old Mar 1, 2011 | 12:51 AM
MTPZ06's Avatar
MTPZ06
Killer deal.
To Brakes
Old Mar 1, 2011 | 07:00 AM
AU N EGL's Avatar
AU N EGL
Remember Ceramic brake pads, with the exception of Carbotech compounds, are NOT for track use.
Old Mar 1, 2011 | 07:36 AM
G.Rossman's Avatar
G.Rossman
What comes from the factory?
Old Mar 1, 2011 | 07:57 AM
AU N EGL's Avatar
AU N EGL
IIRC the stock Corvette and Z06 brake pads are Carbon Metallic compound.
