Took the RedTop dive today
Received 1,506 Likes
No-IL Events Coordinator
C6 of Year Winner (appearance mods) 2019
2018 C6 of Year Finalist
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I hope the red top serves you well!
My OE battery died 4 years ago in the middle of nowhere and the only replacement I could find was a wet cell. I have the terminals torqued properly, sits on an acid absorptive mat and is wrapped in a "blanket". Still gives me the ******* though, any thoughts on the AGM from Sears?
Former Vendor
1 Post
St. Jude Donor '11
StealthLink for Easy Connection of Tenders
For a hassle free connection of your battery maintainers, check out StealthLink at:
www.chargerconnection.com
Former Vendor
1 Post
St. Jude Donor '11
StealthLink Wiring
We mount the electrical receptacle to a custom bracket that is attached to the license plate lamp housing. The wiring from the receptacle is routed behind the rear fascia, over the right rear fender well, forward through the hollow rocker panel, to the battery.
The positive wire is attached to the terminal on the fuse panel and the ground wire is secured to a chassis ground just below the battery.
Premium Supporting Vendor
Antvette, uberC5, Humy, peter pan, wit2pz, TN Vette, jrose7004, and DeeGee, I'm glad to hear you've all been pleased with your Optimas. While Camaros tend not to have parasitic draws as significant as Corvettes, they do still draw some current when parked. Either vehicle will benefit from regular use of a quality battery tender or maintainer. DeeGee is correct about more knowledge of a vehicle's electrical system leading to fewer dead battery issues. Many of the “bad” batteries returned to us now are just deeply-discharged and work fine, when properly recharged. My wife's truck is driving around with a “dead” YellowTop that was returned to us at 7 volts.
JeepTJ, the only charger setting you should be using on your RedTop is the 2-amp setting, as anything above 10 amps can damage your battery. I am concerned that either your vehicle has a significant draw that discharges your battery in four days time or your battery may not be getting fully-charged. Can you tell me what the key-off load is on your car?
c5 BearsFan, I'm sorry to hear about the problems you had with your batteries. What were the circumstances surrounding your issues and the voltage on your returned batteries? Please PM me the contact information for your Advance Auto, as we'd like to follow up on the retail end as well.
Jim McIlvaine
eCare Manager, OPTIMA Batteries, Inc.
www.facebook.com/optimabatteries
Jim McIlvaine
Thanks Chargerconnection for this information. I assume that this would need to be installed while the car is lifted..?
Has anyone here went with this product, it seems like a perfect solution to using up your trickle charger.
Former Vendor
1 Post
St. Jude Donor '11
Installation
To install the StealthLink, the right inboard taillight is removed to gain access to the license plate lamp housing. The car must be jacked to remove the right rear tire and fender liner. A small access panel in the right front fender well is also removed.
Removal of the battery and tray makes the install quite a bit easier, but I've been told it's not required. Typical installation takes less than 2 hours.
PM or email your email address if you'd like me to send the instructions in PDF format.
sales@chargerconnection.com
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
All in a day . . .
Actually, my battery replacement started out with me originally deciding against the optima series since I keep hearing that they are problematic and die right after the 3 year warranty period, so after doing research settled on a Duralast Gold and picked one up at Auto Zone. While the folks there were very helpful, I did not have a good feeling since the first battery they put on the counter for me had acid right on top of it. They went back and found that “another” brand was leaking all over the Duralast ones under it.
I reluctantly took one of these batteries and stopped by the grocery store on my way home. I wiped off the battery before going into the store and when I came out 30 minutes later, the Duralast was leaking a bit right in the trunk of my family vehicle!
At that point, I realized that the lesser of evils was to go with a battery that won’t leak and take a chance of it dying early.
I can only hope that this optima will do good for me, noting that I will be using a trickle charger since I don’t get to drive the vette often. Time will tell…
I still feel that the best bang-for-the-buck is the Costco Kirkland battery at $63.00. Leaks are virtually non-existant after the battery manufacturers have strengthened any weak areas in the cases, quite a few years ago. I've been driving now for 37 years and have never had a leaking battery. Chances are good that I never will.
I have had other electrical gremlins, but nothing to do with the battery.
Oh, and I did need a jump from my wife's Camry when installing the new stereo, I let it run too long without the car running.
My first RedTop lasted only about 9 months, the second one was doing well at 6 years!.....but after a seat control module failed and drained it to ZERO, rather than fuss with re-charging it, I just got another one. I MUST stress that one with 6 years of daily driver use was DOING FINE until it got abused by draining to zero....but the story is not over for it yet...after a few weeks of slow trickle charge, that 6 year old one is now installed and working in my old VWGulf 16 valve 2 liter!!!
They seem to be either VERY VERY good, or not at all..... and not much in between
#33
If you like to walk, buy a Red Top!
#34
Oldtimer
Optima knowledge.
#35
Nothing like buying a $200 battery and having to keep it on a charger so your car will start..
Ill go with the best Costco battery or WalMart battery.. They will at least honor the warranty without any BS
#36
Little Known Trick....?
I bought my 02Z about 10 months ago. I went to the dealer to get it checked out and he mentioned the red top that the previous owner had put in it. The service manager told me a little known secret about C5 vettes is that the drain on the battery can be defeated if you always leave the car in reverse when you shut down. I travel a lot and have been doing this and haven't had any problems at all. The beast fires every time....
#37
#38
#39
3rd_Vette, I'm sorry my previous efforts to assist you did not meet your expectations and I'm sorry to hear you are not pleased with your YellowTop. What is it about the battery or it's performance that is disappointing to you?
Jim McIlvaine
www.powerpacknation.com
Jim McIlvaine
