My TI exhaust bit the dust
So I had noticed what sounded like a heat shield rattle ... could not pin point it then took it to my tuner who found the rattle in the exhaust muffler part of the TI ... Choice to let it rattle was simple for me but he suggested to put it on the dyno compare the pull to the last ... We were down 14 HP from last time .... Un bolt it and a net increase of 16 hp over last time ... so thought is that something is busted loose in there blocking the flow out... Anyone else ever had this?
There isn't really anything in there that could come loose and block airflow.
http://forums.corvetteforum.com/c5-g...6-muffler.html
You'll see all there is is some pipes and the steel wool, which doesn't look like it's going anywhere...
Received 19,547 Likes
'20-'21-'22-'23-'24
Thanks for posting the link which details the inside of a Ti muffler.
Not on the Vette but the cat on my son's Flowmaster broke down causing a blockage. It was a write off unfortunately. I took forever to work that one out
