[Z06] clutch problems
Old Mar 17, 2011 | 09:01 PM
z06nightmare's Avatar
z06nightmare
4th Gear
Default clutch problems
after putting new brake pads on i started my car and the clutch wont come off the floor unless i pull it up with my foot????? i noticed brake fluid comming out between my engine and tranny wtf???? its got 300000 miles on it? HELP ANY IDEAS??
Old Mar 17, 2011 | 09:12 PM
z06nightmare
4th Gear
Old Mar 18, 2011 | 07:51 AM
Paul 75 L82's Avatar
Paul 75 L82
Well, you have a hydraulic problem. You are going to have to have an inspection of the parts to be able to know where the failure is.
Old Mar 18, 2011 | 09:01 AM
bumble-z's Avatar
bumble-z
Sounds as though the slave cylinder took a dump.
Is there a remote clutch bleeder added to your system, for easy
clutch M/C, line/ slave bleeding?
If so, it could have a faulty connection @ the slave.(crush washer, loose connection.)
Old Mar 18, 2011 | 10:00 AM
machz800ps's Avatar
machz800ps
Is that correct 300,000 miles???
Old Mar 18, 2011 | 11:59 AM
81c3's Avatar
81c3
Old Mar 23, 2011 | 01:34 PM
z06nightmare
4th Gear
So how difficult to change out the slave?
Old Mar 23, 2011 | 01:45 PM
RogerZ06's Avatar
RogerZ06
You have to take tranny off.
Old Mar 23, 2011 | 02:04 PM
bumble-z's Avatar
bumble-z
You have to take out more than the tranny.
You are going to have to pull the torque tube, tranny & rear differential.
That is after you pull your exhaust from the collectors back & the tunnel plate.
Might as well be prepared for new slave, throw out bearing, remote clutch bleeder,& pilot bearing.
Would be a great time to repair any leaking seals, gaskets & o rings in the differential & tranny, maybe add a new clutch, pressure plate & fly wheel,
rear tranny brace, & adjustable clutch M/C or stock M/C
Lets not forget about replacing the fluids in the tranny, differential &
clutch resevoire.
There.. That should keep you busy,broke & tired
To clutch problems
