I installed a fog light hid kit just now and let it run for a little bit. The temperature of the fog light housing after 10 minutes was over 200 degrees. That scares me a little....
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Originally Posted by Qwik01
Ok. So that worked.
That seems really hot, I have 35w 6K hid in my fogs and are on everyday with no issues.
The far end closest to the bulb. About 150-160 range towards the outside. I am running a 35w 3300k which is a yellow hid. Compared to the stock halogen bulb after 10 minutes which was around 150-160 degrees. The HID after the same time got up into the 210 degree range. The highest spike I saw was 213. I am curious wether I should run these in the fogs or not.
The factory fog housing has some type of plastic/ceramic bowl structure. It's safe to run HIDs in there but only the 35w version.
