I have not seen this precise question answered. Does the offset of C6 wheels fit on a C5? I currently run 18F & 19R on my 01 Convertible with no issues. But they are not factory wheels. I am looking at picking up a set of factory wheels but not sure if they will fit.... Suggestions?
Does anyone have the backspace measurement for the factory C6 wheels? Backspace = the distance from the flat hub flange to the outside of the rear lip of the wheel. The easiest way to measure this is to lay a straight edge across the back of the wheel and measure down to the hub.
78mm offset on a 10" wheel calculates to ~8" back spacing. For future reference the formula is width/2+the offset converted to inches. (10/2)+(78/25.4)=8.07"
I've seen C6 wheels on a C5 and personally they sit a little too far in for my tastes. Whether or not they rub is really going to depend on what size tire is mounted on them.
