[Z06] Dyno
Old Apr 16, 2011 | 01:59 PM
BLKWDWZ06's Avatar
BLKWDWZ06
Default Dyno
Took the ride in for dyno today, Albuquerque Elevation 5352, temp was 70.
Have a 04 Z06, LG Headers, Haltech, and Magna Flow.
Was a little disappointed by the results 370RWHP, and 360TQ.
He said there was much more to be had with a tune, and that the numbers were not too bad.
Omar
Old Apr 16, 2011 | 02:22 PM
TGstring's Avatar
TGstring
From: cruising between USA and Canada... SAVE THE WAVE!
Omar
dynojet or mustang?
Never Late's Avatar
Never Late
I'm sure you will see around 380-390rwhp from your tune most 02-04z's will put those down full exhaust CAI and tune, headers alone really only give you aroun 10-15hp Its all in the tune.
Old Apr 16, 2011 | 03:17 PM
Z06X's Avatar
Z06X
Certainly depends on the type of dyno you were on.
Old Apr 16, 2011 | 07:14 PM
BLKWDWZ06's Avatar
BLKWDWZ06
Originally Posted by TGstring
dynojet or mustang?
Dynojet, fyi...took my GTO 06 stock as well, 313 rwhp.....does weight play into this at all. It has a 6.0 ls2, I was really surprised at the low number, I was thinking maybe 330?
Old Apr 16, 2011 | 07:15 PM
BLKWDWZ06's Avatar
BLKWDWZ06
Looks like tunes is next step.
Old Apr 17, 2011 | 02:06 AM
2000BSME's Avatar
2000BSME
Omar
why would you be disappointed in this result? You drive a car that advertises 405 hp, so take 15% driveline losses, you're at 345rwhp, add the headers, you have +25hp for your 370rwhp. Halltech and Magnaflow add little to nothing, especially the magnaflow. +25hp for headers is great.
Old Apr 17, 2011 | 02:39 AM
winters97gt's Avatar
winters97gt
I would use 13% loss, but those are still not bad numbers. SAE should correct the numbers, but every dyno is different.
Old Apr 17, 2011 | 08:32 AM
BLKWDWZ06's Avatar
BLKWDWZ06
I guess your are right looking at it through that perspective.
Does weight play into they rwhp numbers, is my z06 lighter therefore it has more rwhp than my GTO.
Old Apr 17, 2011 | 10:08 AM
imavettegirl's Avatar
imavettegirl
weight is not a factor in rwhp.
why would you think that it would factor in?
Old Apr 17, 2011 | 10:09 AM
BLKWDWZ06's Avatar
BLKWDWZ06
the heavier the car, the more weight on the wheels limiting power to propel the weight
Old Apr 17, 2011 | 10:14 AM
imavettegirl
again, no, that is not a factor in rwhp.
Old Apr 17, 2011 | 10:20 AM
BLKWDWZ06's Avatar
BLKWDWZ06
ok, thanks for the clarification
Old Apr 18, 2011 | 01:14 AM
ZZ06's Avatar
ZZ06
I know elevation plays a huge role at the track...not really sure on the dyno though. I have an 01ZO6 and had LG street headers installed along with vararam (which doesnt help for dyno) and Corsa extreme exhaust. W/o a tune off the bat i picked up 24rwhp. After the tune i gained a total of 42rwhp and 40tq.
Old Apr 18, 2011 | 01:32 AM
BLKWDWZ06's Avatar
BLKWDWZ06
will a tune throw the check engine light on?
Old Apr 18, 2011 | 02:24 AM
ZZ06's Avatar
ZZ06
it can depending on how it was tuned. If that has happened post your codes and we can help you with what its telling you.
Old Apr 18, 2011 | 06:52 PM
bud miller's Avatar
bud miller
here is some more info ...and ideas for you...my dyno post from a mo. ago...no headers..but a great tune..
http://forums.corvetteforum.com/c5-z...my-04-z16.html
bud
To Dyno
Old Apr 18, 2011 | 07:13 PM
tcruse's Avatar
tcruse
Those are corrected numbers mine put up that same hp with lg headers, vararam and stingers I'm in Albuquerque. The uncorrected numbers were 303hp to 305hp right? Being this high sucks. That's why I supercharged mine to pick up some nice power in Albuquerque.
Old Apr 18, 2011 | 08:51 PM
BLKWDWZ06's Avatar
BLKWDWZ06
Fantastic, cant wait to see GTO uncorrected numbers, probably south of a stock Hyundai in Houston
Old Apr 18, 2011 | 09:11 PM
tcruse's Avatar
tcruse
I'm assuming your goat is stock if so slightly less then 300 maybe 290ish. I felt bad after my dyno with my headers and then some cat with a miata told me he put up 90hp then I felt bad for him afterwards.
