fender to ground clearance
Old May 2, 2011 | 11:06 PM
RespondsWithGif's Avatar
RespondsWithGif
Default fender to ground clearance
I was wondering if anyone knew what the stock clearance was from the center of the front wheel arch to the ground. Mine is 27 1/8". I'm trying to see if my suspension is settling. If you have a different wheel/tire combo and/or have lowered it please list yours too. Thanks.
Old May 2, 2011 | 11:41 PM
rtpassini's Avatar
rtpassini
St. Jude Donor '11-'12
edit:
26 3/4 in the rear. 26 1/4 front but mine is lowered purposely
Old May 3, 2011 | 08:53 PM
RespondsWithGif
Originally Posted by rtpassini
edit:
Nice, thanks man. Anyone else. Break those tape measures out people
Old May 3, 2011 | 09:01 PM
happa's Avatar
happa
Mine is roughly 24 7/8" front and 26 1/2" in the rear. Mine has been lowered.
Bryan
Old May 3, 2011 | 09:49 PM
rtpassini's Avatar
rtpassini
24 7/8?? are you sure about that? that things gotta be SLAMMED up front and high in the rear.
take a pic from the side.
Old May 4, 2011 | 12:18 AM
Jistari's Avatar
Jistari
I thought I remembered stock hieght in the front as 27 flat but I just checked mine (should be oem, never touched it) and its 27 1/4.
Old May 4, 2011 | 07:29 AM
socalman's Avatar
socalman
St. Jude Donor '10
Measured a dozen 'stock' cars last year at a show, Vert/Coupes/Z's
Front is 27.5 (+/- 1/4)
Rear is 29 (+/-1/4)
Max lowering front (removing bolts) is 25.5
Max lowering rear (7" bolts, maxed out) is 26.5
(Above on base suspension/springs)
Old May 4, 2011 | 02:24 PM
happa's Avatar
happa
Ok I will, i'll remeasure again too. But it is pretty low up front!
Old May 4, 2011 | 04:02 PM
AU N EGL's Avatar
AU N EGL
measure each side.
Old May 4, 2011 | 08:55 PM
happa's Avatar
happa
Ok, I remeasured and I got both sides front 25 1/8 and 26 1/4. and here are some pics as requested
Old May 4, 2011 | 10:44 PM
RespondsWithGif
Happa, how well do you get around with it that low. Like, how often do scrape? Do you live in a hilly area?
Old May 4, 2011 | 11:43 PM
rtpassini's Avatar
rtpassini
i scrape everywhere! thats why i cant imagine being lower.
Old May 5, 2011 | 05:44 PM
happa's Avatar
happa
Its not too bad, but I do scrape alot going over speed bumps. But just driving around hardly at all. I live right above yea, Im in Simpsonville/Greenville area.
Bryan
Old May 5, 2011 | 05:58 PM
killain's Avatar
killain
Oldtimer
Default Uneven Measuremeny !
I've had a problem since I bought the car, it's 26 3/4 on the passengers side and it 27 & 3/16 on the drivers side. I asked why and nobody knew at the dealership and so they replaced the front spring under warranty. Took them a week to do the work, and when I got it back i had to spend 2 1/2 hours cleaning the black grease out of the carpets. Then they gave me a lot of talk about ride height and Trim height ? I don't know a thing about it, but I guess I'll take to my expert suspension shop and see what they say. For me, i don't understand how when you build a car and mount it on a chassis how can one side be almost over a 1/2 inches ?
If that's the way to build cars why doesn't all 2003 corvettes ride lower on one side than the other ?
To fender to ground clearance
