Help! Signal Indicators Bulb Replace ?
Need to change out the front Signal Indicator Bulbs, ironically Owners Manual doesn't even acknowledge they exist?
I can see them with hood and headlights up, but can't reach them ?
Is there a simple trick that I am missing on this?
WARNING: after (15? 20?) minutes the lights will close DANGEROUS. You should be able to complete the task in 2-3 minutes with no issues. Just don't stop in the middle for a beer.
Go in through the brake ducts - not easy with a Z06 or if you have screens
Go in through the bottom by taking out the bottom panel
The one that works for me is:
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It comes out by turning the bulb holder a ¼ turn counter clockwise but it has a plastic clip which you need to squeeze to release it. Here’s how the bulb fits into the lamp unit. The DRL bulb is the lower of the two.
Here’s the light socket. This one’s after market but it gives you the idea. You can see the clip you need to squeeze.
BTW, if you ever need to replace this socket the part #s are GM 12083689, AC Delco LS15 or Dorman 85882 (Thanks to UM Rebel)
Change the bulb. It’s a push fit into the lamp holder. Push it home firmly but don’t handle the glass. Use latex gloves if you have them. Reseat the bulb holder and turn clockwise until it clicks back in place. Put the plastic headlight housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
It’s a 10 minute job. Some guys have had the lights close if they’ve taken a while to do the fix. If you’re worried about that, disconnect the battery once the lights are up.
The bulb is a 4157NA
Some guys with big arms remove the hood adjusting screw for better access. Guys with even bigger arms have had to take off the headlight cover. Four torx screws (2 back, 1 each side). Take the back ones off first with the lamps down. Raise the lights and take the side ones out.
Before I started taking the lights apart to do the HID projectors I was reticent to screw with anything fearing that when I put it back together something wouldnt line up. The way its designed, thats not gonna happen. The open/close cycle is regulated by resistance at each end, so where ever you leave them when you hit the switch they just go to the end of their travel and stop, even if one was half open and the other was closed.
Also, you dont have to worry about taking the top covers off, they sit on screw height adjusters and that wont change unless you "screw" with them. The panel comes off with four screws and you have access to the light buckets, you lay the panel back on (it just sits on the adjusters), install screws and it lines back up no problem.
Remove the plastic cover around the lamp three screws, note how it slips under a small lip on the front of the underside of the lamp door. Reach in and rotate it out, DeeGee has excellent pictures.
You'll probably need to drive up on ramps or raise the one side to remove the cover panels underneath, if you go with the underside panel method.
