Hood light
Old May 4, 2011 | 12:02 AM
Nevada Smith's Avatar
Nevada Smith
Cruising
Default Hood light
Does anybody know where the fuse is for the hood light. Doesn't work; bulb was missing; got new bulb still doesn't work. maybe fuse pulled also? Never worked since I bought the 99 Corvette.
Old May 4, 2011 | 12:48 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
What about your other interior lights? Does your courtesy lights work? According to my 98 GM service manual it refers to micro relays #42 & #43 for interior lights. That would be in the fuse box located in the floor-board on the passenger side.
Make sure you have the right bulb. The new number is #561.
Old May 4, 2011 | 01:00 AM
DeeGee's Avatar
DeeGee
Just a thought but have you traced the wire down the hood. Theres a connector at the base of the hood that is often dirty or disconnected. A quick clean up may fix it.
The main fuse is #2 in the footwell called "Monitored LD"
Old May 4, 2011 | 08:53 AM
helga203's Avatar
helga203
Does anybody know where the hood light attaches to the car location and pics if possible. Took my hood of back in 2004 when i built my engine and can't find where it connects yes that's right 2004 without hood light. Any help please. Thanks
Old May 4, 2011 | 03:07 PM
gwalker's Avatar
gwalker
[QUOTE=DeeGee;1577519732]Just a thought but have you traced the wire down the hood. Theres a connector at the base of the hood that is often dirty or disconnected. A quick clean up may fix it.
Many times they get disconnected for car shows or working in engine compartment.
I have an 03 and if you are looking at the car from the front, the plug would be to the right of the passanger headlight.
Greg
Old May 4, 2011 | 03:41 PM
timmmmay's Avatar
timmmmay
I've got same problem - bulb's missing still though [which is why the light won't work...] - curious to see how this plays out.
Also - what bulb number is that one?
Old May 4, 2011 | 04:36 PM
HG's Avatar
HG
When you open the hood,look between the hood and the front fascia, it's on the left side. I t may be disconnected. Actually, I think the light is like the cup holder, worthless. I leave mine unplugged and keep the hot end covered .
To Hood light
