a/c window lights out
Old May 5, 2011 | 08:35 PM
barrysz06's Avatar
barrysz06
Default a/c window lights out
temp and other readouts in window next to ac control **** will not show was getting dimmer now gone dealer replaced blinker relay remv dash but worked for a while what type of light works these readouts?
Old May 5, 2011 | 08:59 PM
You can try and repair the HVAC unit yourself - not hard to do and I have a file that shows the process (involves soldering some connections back together). If you'd like a copy, PM me your e-mail address.
Otherwise, you can contact a vendor like JW Motoring and get an LED upgrade - would look very good.
Old May 5, 2011 | 09:06 PM
barrysz06's Avatar
barrysz06
thanks for help with a/c display email shirleymk@verizon.net
Old May 5, 2011 | 09:21 PM
jraschke11's Avatar
jraschke11
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
If your climate control is having problems, this will fix it most of the time.
A simple forum search before asking would have turned this up right away.
http://forums.corvetteforum.com/c5-t...splay-fix.html
To a/c window lights out
