Another LED thread.......
Old May 8, 2011 | 12:50 PM
Plasticman's Avatar
Plasticman
Default Another LED thread.......
Looking to swap out the tail /brake light bulbs with 3057 / 3157 SMD/SMT LED bulbs.
And keep the existing originals lens (no halos, new lens, etc.). I need them to look stock!
And I want the brightest SMD/SMT LED plug-ins available.
If anyone has done this, what LEDs did you use (and where did you get them)?
I understand that adding load resistors is necessary to keep the proper current for the flasher.
Thanks,
Plasticman
Old May 8, 2011 | 01:00 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I would check with JW @ JWMotoring. He is the LED man to talk to.
http://forums.corvetteforum.com/memb...oring-com.html
Mr.Bill
Old May 8, 2011 | 01:17 PM
UM Rebel's Avatar
UM Rebel
LED's, a waste of time and money, IMHO.
Old May 8, 2011 | 01:42 PM
Plasticman's Avatar
Plasticman
Mr. Bill,
Thanks, and will do.
Rebel,
Have LEDs on my 62 for brake/turns signal, and they are much brighter than the original bulbs. But they came as complete assemblies, that included a stock looking type lens.
LEDs also come on quicker (.4 second from what I have read), and alert the idiot tailgating you a little more time to react.
I also have them as my front running lights on the 62, and due to less current and heat, they do not "transfer" the amber coating from the bulb to the glass lens, like incandescent bulbs do.
Plasticman
Old May 8, 2011 | 02:23 PM
UM Rebel's Avatar
UM Rebel
Originally Posted by Plasticman
Rebel,
Plasticman
I'm doubting that .4 second quicker, but I'll let you try to time the difference. You can get brighter with Sylvania Silverstar incandescents. Problems with them, they are expensive and short life span. The only place I think you MAY and I emphasize MAY make a case for LED's is in DRL/Turns. The incondescents get very hot and many times crack the housing. As you know simply replacing with LED's will cause turns to hyperflash. If you try to compensate for the hyperflash with resistors, the resistors will get very hot. Where will you mount them? Not on anything plastic I hope! Instead of resistors you can get a "hyperflash harness". That installs up in the dash on drivers side ... cost about $75 and is a PITA to install. I played the game and now I'm back to stock incandescents. But good luck to you!
Old May 8, 2011 | 02:50 PM
Plasticman's Avatar
Plasticman
Rebel,
Believe what you want. Obvious from the get go I know what I want. If you think me an idiot, then go with it.
Go away, far away................
Plasticman
Old May 8, 2011 | 03:54 PM
UM Rebel's Avatar
UM Rebel
Rebel,
Plasticman
Hey, I'm not saying you are an idiot nor am I being a smart a$$. Just letting you know my experience and opinion. That's what you asked for.
Old May 8, 2011 | 04:02 PM
Mr.Bill's Avatar
Mr.Bill
Old May 8, 2011 | 05:04 PM
wascapsfan's Avatar
wascapsfan
It's better to keep quiet and have people THINK you're ignorant then to open your mouth and have it confirmed.
Just thought you'd take the day and find a way to blow the candles off someone's cake for absolutely no reason, ehhh?
If you have nothing good to say then:
KEEP YOUR MOUTH/PEN SHUT!
Old May 8, 2011 | 05:08 PM
Mr.Bill's Avatar
Mr.Bill
I agree, He sure got points on this thread...lol
To Another LED thread.......
