Tire Inflation Problem
Old May 16, 2011 | 05:55 PM
bucknutt76's Avatar
bucknutt76
Default Tire Inflation Problem
Alright so here is whats happening. I fill the left rear tire to around 32 psi and in a few days the tps reads it has lost about 10 or so psi. I have take it to two tire shops and they both say they cant find a leak. I was thinking of using the green slime stuff thats supposed to be tps safe. Any thoughts on how to keep this from happening at all? Thanks alot for the help.
Old May 16, 2011 | 06:16 PM
hotwheels57's Avatar
hotwheels57
Did you double check the pressure with a tire pressure gauge in addition to the tire pressure sensor on the DIC?
I don't have TPS on my Z16, but I know the sensors on my Silverado always show less than what my digital tire pressure gauge shows.
Old May 16, 2011 | 06:18 PM
bucknutt76's Avatar
bucknutt76
Oh yes many many of times, this is an ongoing problem.
Old May 16, 2011 | 06:30 PM
steve8's Avatar
steve8
Probably a rim leak. Fix a flat/slime are not meant for long term solutions.
Old May 16, 2011 | 06:32 PM
bighank's Avatar
bighank
Default I was losing air in one of my wheels a cracked rim on the inside
I kept loosing air in one front wheel. Pulled it and couldn't find a leak in the tire or bead. Looked closely and found a hairline crack from the inside if the rim going about 1 inch. Can usually find these with a hose and slow water coming out of a nozzle. Look for micro bubbles. Should be none.
Another guess is the o ring on the tpms. When they changed tires it leaked there. or could be the valve stem.
Old May 16, 2011 | 06:40 PM
bucknutt76's Avatar
bucknutt76
Ok I will try another tire shop then and see what they come back with thanks for the help guys.
Old May 16, 2011 | 06:41 PM
Rexde1's Avatar
Rexde1
I just had the same problem and sprayed the entire wheel and tire with windex. Come back later and find the bubbles.
Old May 16, 2011 | 06:54 PM
dbaker's Avatar
dbaker
You may have a problem with "Tire Corrosion".I had this problem last year.A chemical reaction with the wheel,tire and heat,cold & humidity.
Mine had a build-up around the bead causing a slow leak...about 2-3 lbs a week.
I had the tires removed,the wheels scraped smooth and repainted on the inside.
http://www.thedenverchannel.com/news...48/detail.html
This solved my prob.
\db2
carolina
Old May 16, 2011 | 07:12 PM
jrose7004's Avatar
jrose7004
I'd say that you have a crake in the wheel. What kind of wheels do you have?
To Tire Inflation Problem
