1214 code repair + driveability
My question is when the box is off and you drive it , does the readout allow you to check tire preeesures and oil temp etc or does it just say sevrvice abs/traction control
In spite of all this, I love my C5 and will do whatever it takes to keep it on the road, even it it means to eventually strip it of the monkey-designed, baboon-approved electrical systems, and to re-wire it like a race car.
Best wishes on your ABS situation....
But you can drive it without the box, just make sure you tape over the exposed terminals and remember, you won't have ABS/TC/Stability control. Just clear the error codes.
Perhaps you should read it! You will discover an engineering flaw in the ABS system at very low speed.
The book says you can safely drive the car with EBCM removed. You just lose the protection of the functions the EBCM controls; AH, TCS and ABS.
.......and to top it all off she just called Evil-Twin an "idiot monkey" :bb...it would be monumental if Bill was here to step in
"Modern cars will be crushed before their time, due only to crap electrical systems designed by idiot monkeys...as a qualified high reliability electrical systems engineer, I am qualified to have an opinion on this subject....It makes me want to do bad things to the idiots that designed these crummy systems, and approved their use in a machine that can kill the operator or passenger, and other innocent people , if the right cluster of failures occurs.
In spite of all this, I love my C5 and will do whatever it takes to keep it on the road, even it it means to eventually strip it of the monkey-designed, baboon-approved electrical systems, and to re-wire it like a race car."
I will send a check to anyone who can get ET to step in
It is the fact that the solder contains little or no lead, thanks to the ban on lead.
This is a common problem also with foreign cars also.
I drove for about a year without it while procrastinating the repair. No issues, but just make sure you're not putting yourself in a situation where you'd regret not having those systems.
(Also drove mine without EBCM while it was out to ABSFixer, no problems at all)
