Need help finding extra cooling radiator
Old May 21, 2011 | 10:04 PM
Redvette_22's Avatar
Redvette_22
Default Need help finding extra cooling radiator
I need to find a vendor or dealer who sells "extra cooling" radiators to fit my 2003 Auto Vette. I do not want to jump thru hoops to get it to fit my car either, after all, if you pay a bunch of money for a unit it should fit properly. The car is 98% drag race so while I want it to keep the car cooler then OEM single core, I will not cut the car up to make it fit, and want the OEM fans to fit.
Old May 21, 2011 | 10:50 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Get a DeWitts and all will be good
Old May 22, 2011 | 08:23 AM
Redvette_22
Have you installed one in your own car? If so, what temperature drop did you see by installing it? Was it a true "drop in" or did you have to modify anything, like fan shroud, cooling fan mounts or brackets, etc.?
Old May 22, 2011 | 08:49 AM
CHJ In Virginia's Avatar
CHJ In Virginia
There are two different direct bolt in dual core aluminum radiators available for your car. The Dewitts is the one that I use in my track car. http://www.dewitts.com/ It is truly a direct bolt in using the stock fans, mounts etc. I saw a 20+ degree drop in coolant temps after installation. The other is a Ron Davis - http://www.rondavisradiators.com/ They also come highly recommended by many forum members. The Davis is a little more pricy than the Dewitts. You could not go wrong with either unit.
Old May 22, 2011 | 09:24 AM
Redvette_22
On the DeWitts radiator, A01A, for my 03 Auto, would be $665 shipped to me, are there any vendors here that can give me a better price then this? I am ready to order a radiator this week from somebody to be ready for the next race event on June 11th.
Old May 22, 2011 | 03:57 PM
Redvette_22
Originally Posted by 8VETTE7
wait until Tom DeWitt has his annual sale.
When was that "Annual" sale at?
Old May 22, 2011 | 11:05 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I had one on my boosted C5 and put it on when I did the motor and boost at the same time so no before or after temps, but in Texas weather I was able to run my AC and not get over 220 in stop and go traffic and normal driving about 194 in the summer.
Old May 22, 2011 | 11:12 PM
Redvette_22
When you did this, did you have to modify the fan shroud or the cooling fan assy to fit? When you had the original radiator and before you installed the blower, what were the temps the car ran at under the same conditions? Also, did you have a low temp thermostat before the blower or even after?
Old May 22, 2011 | 11:31 PM
tlove32's Avatar
tlove32
While I have a dewitts, forum vendor RSD also has a direct fit dual core radiator
Old May 22, 2011 | 11:59 PM
Redvette_22
I cannot find his website, do you have it?
Old May 23, 2011 | 12:24 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Here you go.
RaceSpecialtyDesigns.com
Steve@RaceSpecialtyDesigns.com
Old May 23, 2011 | 07:19 AM
Redvette_22
Thanks, I sent an email to them
Old May 23, 2011 | 07:47 AM
Bigthainitty's Avatar
Bigthainitty
I have a DeWitts in my magnacharged vette combined with the low temp thermostat and heat extractor hood the car never gets hotter than 194* in traffic.....fit was great and it's good peace of mind
Old Jul 23, 2011 | 09:45 PM
D C's Avatar
D C
USMC (retired)
WOW, I wish mine was like that. What was your boosted setup? engine size, type of blower (YSi?), what radiator, what fans, what water pump and what thermostat?
Old Jul 23, 2011 | 09:50 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I got the same one for mine but I did not get it for the A4 I got it for the MN6 and use a external Tranny Cooler-
By doing this you keep both heat sources away from eachother and keep things much cooler!
Thanks,Matt
Old Jul 23, 2011 | 09:51 PM
madmatt9471
They are on the left side of the forum under cooling:
Thanks,Matt
Old Jul 24, 2011 | 09:11 AM
rdwiv's Avatar
rdwiv
Forum member Patches recently added a DeWitt's and kept the factory fans. excellent pics on the install:
http://forums.corvetteforum.com/c5-g...ver-again.html
Good Luck!
To Need help finding extra cooling radiator
Old Jul 24, 2011 | 10:01 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
This thread is good timing as I am thinking of a new radiator as well. My car now has a S/C and trans cooler, and things are getting a little packed in the front end. I was driving in 99* temps with A/C on and I was at 217*. I have seen others run at 220-230*. Is it worth it to invest $600ish on a new DeWitts with my temps at 217* on 99* day, or Do you think I'm good with stock unit?
Old Jul 24, 2011 | 10:15 AM
AU N EGL's Avatar
AU N EGL
Have you cleaned your radiator out ? they get clogged with dirt, sand and grass very easily.
Old Jul 24, 2011 | 10:20 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
My S/C was put in 3 months ago and all the debris was removed and new coolant was put in. It only runs 210-217* when it is 92*+. I am at 185-195 on normal days, 90* or cooler!
