Rear view camera
Old May 24, 2011 | 10:47 PM
Bigcountry7's Avatar
Bigcountry7
Default Rear view camera
Does anyone have an opinion on which is the best rear view camera? How hard was install??
Old May 24, 2011 | 10:48 PM
corvettedaddy11's Avatar
corvettedaddy11
I want one ..!
Old May 24, 2011 | 10:58 PM
olbear1962's Avatar
olbear1962
I installed the Kenwood camera reccomended for my DD NAV system. No regrets, best thing I have done, makes it so much easier in a car park.
Old May 24, 2011 | 11:14 PM
Razzputon's Avatar
Razzputon
heh I'm good with the rear. I need one for my front bumper. Every time I park.....
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I've seen some guys mod the cameras and install them on their front bumper to help avoid parking blocks/curbs.
Old May 24, 2011 | 11:21 PM
olbear1962's Avatar
olbear1962
Me too, would like to do this mod myself sometime....
Old May 24, 2011 | 11:32 PM
MSG C5's Avatar
MSG C5
Since I own a vert and drive top down 90% of the time, I really think I would benefit more from having the camera mounted in the front. I try to back in most of the time, however pulling in nose first can really be hazardous at times.
Old May 24, 2011 | 11:41 PM
Navybluevette's Avatar
Navybluevette
St. Jude Donor '12-'13-'14-'15-'16-'17
I have two camera's on my C5 coupe, one in the front and one in the rear they are hooked up to my rear view mirror, that has Nav system and 3 video hook ups. I have the rear camera set up to when the car is in reverse its on, if I want to see the front I have to select video 1, when the car is in any forward gears my Nav system is on. I got the mirror from Dennis at Double D Mods. The camera's I'm using are $30 camera's that were purchased on Flea Bay. The were not very hard to install.
Old May 24, 2011 | 11:49 PM
MSG C5's Avatar
MSG C5
Sounds great! Pics of the mirror/cameras?
Old May 25, 2011 | 12:01 AM
Navybluevette
It will be a day or two before I can get some pictures, we're getting slammed with bad weather here in north Texas.
Old May 25, 2011 | 01:17 AM
Jistari's Avatar
Jistari
Not on the vette but I put one on my wifes SUV. It also was the Kenwood one and it wasnt cheap (like $200), but it was the only one that had the specific mode I needed for her (spine surgery, cant turn head to far, this one has a display mode that gives you split screen 90 degrees left and 90 degrees right, for backing out of a spot at the mall).
One thing I would do if I were doing one on the vette is maybe look for a CCA rather than the CMOS type camera. The CMOS based ones are lower res and pretty crappy (IMO) in display quality, they are cheaper though.
YMMV
Old May 25, 2011 | 01:43 AM
DeeGee's Avatar
DeeGee
I fitted a cheapy which I found on E Bay. It was the type with a tuning **** for the frequency. I found it constantly drifted off and the picture went fuzzy. I pulled it out. I wish I'd invested a few more $$ on a decent one.
Have to say it was a bit OTT for a Vert.
One thing I've often toyed with is fitting an ovetaking camera. Driving on the left, the first peek out from behind a car I want to overtake is the worst moment. I'm often quite a way out onto the other side before I get a good look at oncoming traffic. If I did fit one it would have to be high resolution though.
Old May 25, 2011 | 08:50 AM
Bigcountry7
YMMV
Thanks for the info
Interesting. I am sure you will do a write up if you ever go through with it!
Old May 25, 2011 | 09:09 AM
c5vetteguy's Avatar
c5vetteguy
Here you go!
http://forums.corvetteforum.com/c5-g...up-camera.html
Old May 25, 2011 | 12:48 PM
Bigcountry7
Originally Posted by c5vetteguy
Thanks for the link!
Old May 25, 2011 | 03:38 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
169.99 for mirror and camera
3.5" RCD Rearview Mirror Monitor
Black License Bar Camera
120-degree Angled Waterproof Lens
2 Video Inputs
Remote Control
Reverse Override
Anti-Glare Coating
High Resolution Display
Includes stem mount, hardware and 6-foot RCA power cable
pic of mirror
pic of camera
Old May 25, 2011 | 03:41 PM
0Double D Mods
Former Vendor
here is the NAV mirror that you can also add the camera too
329.99 for the mirror and mounting bracket
add camera for 39.99(same as above)
To Rear view camera
Old May 25, 2011 | 04:37 PM
c59001's Avatar
c59001
I flush mounted mine in the license plate. putting one in the front isn't a bad idea...
Old May 25, 2011 | 04:43 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
I tried the link to this product on your site in the other thread you linked to above - 404 page not found error....
Have you installed/used this product other than the one customer described in the linked thread?
Old May 26, 2011 | 02:20 AM
Jistari's Avatar
Jistari
YMMV
Sorry that should have read CCD (not CCA)
Originally Posted by Bigcountry7
Thanks for the info
