water wetter.
Old Jun 1, 2011 | 01:17 PM
Cirrus8's Avatar
Cirrus8
Default water wetter.
Has anyone tried WATER WETTER in their cooling systems. I have heard that it will lower the operating temp by 10 degrees!! Any truth to this?
Old Jun 1, 2011 | 01:25 PM
hotwheels57's Avatar
hotwheels57
Best asked in C5 Tech where it's usually discussed. Or, in C5 Tech, use search or search this forum (in the red banner). Use "water wetter" as keywords. That should lead you to the discussion from about two weeks ago (and many more threads).
I use 1-2 bottles of it in my cooling systems of our daily drivers, my Z16 and my previous modified tri five Chevy cars. Don't expect miracles. In hot humid AZ summers, I don't see a significant cooling effect, but it does stabilize the cooling system. It's a surfactant which aids in breaking down surface tension. Basically, it makes the coolant more efficient against hot metal.
http://www.redlineoil.com/Products.aspx?pcid=10
http://www.spraytec.com/24/surfactan...g-water-wetter
Old Jun 1, 2011 | 01:29 PM
melvingregory's Avatar
melvingregory
Water Wetter is good stuff, I used it with my C2 and C3's to help with the overheating. But, with the C5's I haven't had any issues with overheating. Newer cars need to be closer to recommended temp levels for all the emissions and such to work properly. I keep the trash out of the radiator and such. C5's are bottom suckers and I have found that to be the problem most of the time. Also, note when the last time the coolant was changed and the system flushed. I use my vert several times a year in our local parades and it has yet to heat up. Some days I do run the AC to make sure the fans stay on all the time on a long parade route.
Old Jun 1, 2011 | 02:12 PM
runner140*'s Avatar
runner140*
It worked for me.....but I:
Got a new radiator cap.
Did a full system flush and replaced with a 50/50 mix of DexCool and distilled water (with Water Wetter).
Purchased a new t-stat.
Purchased new hoses.
Pulled the radiator and had it cleaned out.
Vette runs in the low 190's, now.
Old Jun 1, 2011 | 02:18 PM
bop's Avatar
bop
I used it in my C-3 and it lowered my temperature by about 10 degrees.
Old Jun 1, 2011 | 03:50 PM
Bash's Avatar
Bash
I was a little low in my resv. so I just added in a bottle of WW & here are some results:
Car = 02 c5z - Cammed/Bolt-ons/Slammed to the ground (less air underneath = more heat)/180 deg thermostat
Pre-WW temps:
90+ (Houston,Texas) deg temps = 195 deg on Highway / 205deg in the City (No A/C)
90+ (Houston,Texas) deg temps with A/C = 200 deg on Highway / 210+ in the city (With A/C)
Post-WW temps (I never changed coolant mixture, still 50/50):
90+ (Houston,Texas) deg temps = 185-190 deg on Highway / 190 deg in the City (No A/C)
90+ (Houston,Texas) deg temps with A/C = 190 deg on Highway / 200-205 in the city (With A/C)
Old Jun 1, 2011 | 04:11 PM
AU N EGL's Avatar
AU N EGL
Use TWO bottles of water wetter
Old Jun 1, 2011 | 06:01 PM
RSchleder's Avatar
RSchleder
I used it in my Street Rod that was powered by a GM EFI Ram Jet 350. It seemed to help to some degree, however, as it's been said above---don't expect miracles!!!
Old Jun 1, 2011 | 06:05 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
That's what I'll try, one bottle seems to not have helped at all.
Old Jun 1, 2011 | 06:40 PM
Jeff in Den's Avatar
Jeff in Den
Dropped mine an easy 10-15 degrees...down to about 192-196 in every day driving.
But...
I too changed the t-stat and did a drain, fresh water flush, and then added fresh coolant.
WillEE's Avatar
WillEE
I've tried it on 2 different occassions/cars. Saw absolutely no diff. in the temps. (which exceeded the T-stat opening design point) I think the claims are bogus and much like all the other over-priced hokus-pokus elixyrs sold in same section such as belt dressing and radiator repair juice. Your better off going out and spending $20 on a good pizza.
Old Jun 1, 2011 | 06:46 PM
dbaker's Avatar
dbaker
I've used it...it works ok.
This spring ( coolant flush),I added a bottle of Amsoil Coolant Boost to give it a try.
Before I would run 189-191 most all the time.Today it was 96 in Carolina with a heat index of 102.My 02Z settles down to a cool 185 with stock stat.
I'm pleased.
\db2
carolina
Old Jun 1, 2011 | 07:06 PM
baxsom's Avatar
baxsom
water wetter is an excellent addition to straight water. On my track bike where glycol coolant is not allowed you have to run plain water. The water wetter provides the lubrication properties necessary to keep the pump working.
Old Jun 2, 2011 | 12:07 AM
81c3's Avatar
81c3
Never needed it in my C4's or C5's, but I did use it in my 79Z28 that I had and it worked well. I had about a 7-8 degree drop in temperature.
Old Jun 2, 2011 | 12:11 AM
1 C6 2NV's Avatar
1 C6 2NV
Myth Buster
Ive used it often. I use one bottle, 20 ozs of antifreeze and demineralized water. pulled 7 degrees and good for 20 degrees f protection. Thats plenty where I live
Old Jun 2, 2011 | 05:48 AM
fastyellowss's Avatar
fastyellowss
I have used it in my 72 Chevelle 468 BBC. All Ive noticed is that it takes longer for the temp to come up, but it still gets to full temp and stays there.
Old Jun 2, 2011 | 05:54 AM
Cybermind's Avatar
Cybermind
As others have mentioned, this product is excellent for use with straight water (racing applications). Other than that, I'm not convinced that it is a good thing to use with our Dexcool coolants. Have there been any longterm studies on how it interacts with the coolant, radiator, pump, etc. I'm just not big into additives of any kind. Just my two cents.
To water wetter.
Old Jun 2, 2011 | 06:58 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I used it in my C4 and it seemed to work well especially in the summer time here in the desert!
Don't know about a 10* drop but it really seemed better
Thanks,Matt
Old Jun 2, 2011 | 07:34 AM
dbaker's Avatar
dbaker
Yep,all these "cooler" prods work best with water.You can expect less with a 50/50 anti-freeze mix.
\db2
carolina
Old Jun 2, 2011 | 07:53 AM
AU N EGL's Avatar
AU N EGL
IIRC Water wetter is more of a lubricant to used when WATER not coolant is used in the radiator.
Water Wetter does a great job. However, one needs to clean out the radiator with an air hose or garden hose first.
If your radiator is over 6 years, you may want to consider taking the radiator out of the car, and having a shop dip the radiator in to very hot water, to clean the fins.
So much crap, sand, dirt, grass, mickyDs bags, dead things get into and clog the fins. Most ppl dont notice the slow temp climbing.
First thing they do and the INCORRECT thing they do is put a lower T-stat on. NO. clean the radiator and ac condenser out
Cleaning your radiator fins out once a year makes a huge difference to your cars cooling abilities.
